Swap is Complete -- Lincoln LS Engine in My X-type Jag.
Old 11-11-2010, 12:12 AM
Tec Nine's Avatar
impressive
Old 11-11-2010, 07:52 PM
triumph_013's Avatar
Very nice. I may use this once I get this Jag.
So is this the same exact 3.0 that is in the Jags? Did you cross reference the part numbers on the two different ECUs to make sure they were the same?
Old 11-16-2010, 11:06 PM
mushu1340's Avatar
Default nice job
hey do you have a manual trans or auto? did you use the same injectors from your 2.5? could you contact me mushu1430@aol.com. I'm doing something similar to my x thanks
Old 04-05-2011, 03:24 PM
2002xtype2516's Avatar
hey ***** im gonna pull the engine out fo the top as well i have a 2002 xtype 3.0 any hints on the things you needed to do on the removal and installation???
Old 04-06-2011, 07:25 AM
mushu1340's Avatar
Default Removal
It's a big pain in the *** doing it that way, I did it that way. I had to remove it again. It's a lot easier going from the bottom.
Old 04-08-2011, 01:40 PM
cammerfe's Avatar
Default Reverse Swap
Very Impressive job---but you broke my heart. I thought you were going to show how to do the job on the V-8. (I'm in process of going the other way, by installing an AJ27 in an LS.
KS
sov211 (03-24-2016)
Old 04-08-2011, 09:39 PM
MrBachelor's Avatar
How long is that swap going to take you KS? Been working on that Land Speed LS a while now...
  #28
Old 04-09-2011, 12:29 AM
cammerfe's Avatar
Clear 'til I get it done. I'm also trying to get a small business going at the same time and the money necessary to finish the engine has mostly been going into the business. I did just get such things as a couple of sets of cam blanks and a pan with pick-ups installed for going to a dry-sump.
KS
Old 11-20-2011, 12:51 AM
willy-k's Avatar
Ive already sold this Jag....... it was a real easy swap! No computer changes. I used the original electronics and just swaped a few parts over from one engine to another....weekend job and no special tools but the engine lift.
Now you all know, dont say jag at the parts store say FORD..cheaper parts and its in stock.
I will check this post from time to time,if you have any Q's.
The following 3 users liked this post by willy-k:
Panthro (04-06-2018), sov211 (03-24-2016), Thang Nguyen (10-01-2016)
  #30
Old 11-20-2011, 08:37 AM
brucelee's Avatar
Amazing bit of repair work. Nice job.
  #31
Old 11-21-2011, 03:08 PM
disguay's Avatar
stellar write up!!!! This is a very good thing to keep in mind if my engine goes to crap seeing as the ls engines are probably cheaper than the x type engines.
  #32
Old 01-18-2012, 07:52 PM
felixand's Avatar
Default Trans
Hey there, I might have missed it, but was your X-Type a manual or auto trans?
-felix
  #33
Old 01-22-2012, 10:50 AM
JasonERF's Avatar
Very impressive work! For a moment I was wondering why you'd put that engine in until I saw you had a 2.5L.
Nearly every day I drive my 3.0 sport I think i wish i had more powweerrrr!
  #34
Old 02-27-2012, 12:03 PM
Ojo_Verde's Avatar
Great job! I plan on doing the same project with my 2000 Jaguar S-Type 4.0 with a Lincoln ls 3.9. From what I've found the swap can be done, I will start the project sometime in the next week or so.
  #35
Old 05-19-2012, 06:26 PM
Mr.Knight's Avatar
Default Pondering something similar
Just bought an s type 3.0 with 182,000 miles. I believe I've blown the oil pan gasket in this past week and am not thrilled. In as much as the car has considerable mileage, I am entertaining the thought taking the opportunity to rebuild the engine. Could my s type 3.0 be rebuilt onto an ls block?
  #36
Old 05-20-2012, 12:57 AM
65ras's Avatar
I'm not surprised about the compatibility. I've tried to tell multiple people my 2000 s-type 3.0 has the same trans as a 2000 Lincoln LS 3.0. But because of the lack of cross-reference made available, people swapping Ford parts from Fords into their Jaguars with Ford drive-trains will be the narrow road. I barely started rebuilding my LS trans but I'm making my part swap too, however my swap is identicle. Good job and enjoy!
  #37
Old 05-20-2012, 10:09 AM
jagryan85's Avatar
you said you kept your old ecu on, i'm guessing that is the one off the 2.5? Your engine will not have full power because your ecu wont have the fuel settings the same as the 3.0 maps. I replaced my 2.5 with a 3.0 and kept the same ecu, but having a race with another 3.0 and lost quite drastically so i bought a 3.0 ecu, and now both cars kept next to each other down a 1 mile stretch of road! You'll see what i mean if you get the chance to race with another 3.0
  #38
Old 05-21-2012, 03:42 PM
BuckMan's Avatar
Good Job!
  #39
Old 05-21-2012, 04:17 PM
tony2u's Avatar
Thumbs up
Well Done !
  #40
Old 08-27-2012, 10:51 AM
xplicitwhips's Avatar
u conviced me into doing the ls swap into my 02 xtype after blowing a hole in the block wasnt all that easy but i learned a little more about the jag..been riding with the ls swap for a month now with no problems...
Quick Reply: Swap is Complete -- Lincoln LS Engine in My X-type Jag.
