Need help asap !!!!
Old 06-10-2011, 08:55 AM
teflondon's Avatar
Question Need help asap !!!!
Good morning Jag Family.... I'm in need of some help ASAP... I'm trying to purchase a transfer case from a shop but he doesn't know what year of X it came out of... he's replace the seals and all of the mechanical part he could... he's selling it for 550.00 w/ 6mth warranty..
all he was able to give me was the part number off of the casing which is
1X4W-7H470-D
I called Jaguar dealer and they said they wouldn't be able to know w/o the serial #
thanks family... I need to pull the trigger FAST... so any help will be greatly appreciated !
Old 06-10-2011, 09:27 AM
rothe's Avatar
Have you tried doing a Google search on that part number, maybe with an extra search term to narrow it down - "jaguar". I did, and came up with two pages in Russian that contain that part number. From the Google results, you can use Google translate to view it in English.
This page:
Google Translate
seems to indicate that it's from a 2002 model. I don't know that I'd take that as Gospel without trying to confirm it by other means, but for now that's all you have to go on.
Good luck.
Old 06-10-2011, 10:04 AM
teflondon's Avatar
thanks @ rothe.. i'll look and see.
Old 06-10-2011, 03:10 PM
1X4W-7H470-D
Be very careful with a transfer case of unknown origin. The link shaft to the RH axle [which should come already installed in the transfer case] has to be removed properly and gently during their rebuilding, to prevent damage to a seal in the heart of the case. If the circlip on the LH side of the linkshaft is not REMOVED BEFORE the linkshaft is taken out [or inserted], the internal seal is damaged and t-case fluid and trans fluid come together once the thing is all reassembled. Then you've wasted your transmission, too.
Just some friendly advice........
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
Collector1
09-26-2015 05:28 PM
European_Auto11558
09-25-2015 08:05 PM
MrMellor
09-21-2015 10:10 PM
Quick Reply: Need help asap !!!!
