Center Digital Console Display
Wondering if there is an issue with my center console or does it need some kind of programming? so until today I wasn't really paying attention, although I did wonder why it is so, but my center console would always just display "Tuning" above the center line and "FM" below when radio is on. FM didn't really concern me since I was listening to FM radio but I couldn't figure out why the top was always just saying Tuning. I took my car for service today and got a Range Rover with what looks like a very similar infotainment including an almost identical center console. When listening to music this console actually displays the station number and song being played instead of the "Tuning" message. Is there something wrong with mine or do I just need to set it up?
Keep in mind, we've got TWO display screens for the driver to see, so depending on how you've set up the menu, we might not be talking about the same "tuning" message.
I have the 8-inch standard intouch main screen (not the 10-inch Pro version). So if I am playing a radio station, and I have chosen HD-radio ON, the 8 inch screen will play the station with NO tuning message at all.
But I might hear a slight fading of the sound now and then.
At the same time, I have the TFT screen (the little driver's screen that sits between the speedometer and the RPM indicator dial)---I have that set to display the radio station too. And the TFT WILL give me that "tuning" message every time the radio station I'm listening to gets a little weak.
So, your "tuning" message may be indicating your radio reception is a bit difficult in your driving route--or that your favorite HD radio station is fading out a bit.
I explained from the start I was talking about the display between speedometer and RPM indicator. I don't believe this has anything to do with radio station fading out. It always says tuning, I had a range rover for a week and it shoed song and artist just fine on the same route. I now believe its how the XE was designed (even though it makes no sense) or possibly this will get fixed with some software updates later on. It seems everyone sees the tuning message.
LOL, okay.
It's just that I read your description as simply "the center console", and I know to some, the center of the dashboard can be confused with the center of the driver's cluster.
But you CAN set the car to disable that message on your cluster if you want. If it's annoying, go into the 'vehicle display' menu on your center console (LOL, the driver's center console), and pick another item to display while you're driving.
I prefer not to see the radio stations through my steering wheel...
I have the same message between the speedometer and RPM meter when playing the radio. When playing radio, it shows tuning, when playing BT music, it displays the song title. I think its a poor radio signal. Radio reception is not that great in this car. Can't get anything but static in the garage. Other cars have played fine.
I have found that in HD radios, "tuning" is actually the automatic programming of the radio trying to stay on the sharpest part of the station as your car travels. It's not that it's LOSING the station, it's just being unnecessarily picky about actively fine-tuning.
There is an option in the intouch menu called "manual tuning" which may stop the radio from automatically fine-tuning all the time.
OR, try using the radio with the HD radio OFF (your area may not even need HD frequency much.
