XE ( X760 ) 2015 -
Eco On/Off and Secondary Battery?
Old 03-22-2017, 06:34 PM
Originally Posted by chariot44
Vap seems very promising indeed, with disabling an irritating feature + a remap.
I hope they can come up with something for the 25T soon.
Our hands are tied at the moment with our tool companies, None of them talk "efficiently" with the some 2017+ models, which is the only 25t's I have access to and falls in this category. Earlier than 2017 we didn't have this version available in Canada, which makes it hard to design something perfect and safe. There's not much difference in the software of the PCM itself for pre and post 2017, just how the communication is with the tools. Once we get this tool communication issue resolved, we'll be able to speed-line the 25t and 20D software development.
My apologies for the delays
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
Old 03-22-2017, 10:53 PM
chariot44's Avatar
No worries there. It's always reassuring to go with perfectionists.
My 25T is MY17 and will be looking forward to the complete product.
Old 04-05-2017, 07:00 PM
taurusjds's Avatar
Default Start Stop Disable
Anyone that is interested - there is no secondary battery on the XE for a disconnect
Easiest fix to disable stop / start is to disconnect the large grey connector with one large black wire coming from it ( just above and to the right of the fuse box on the right side of the trunk. Access is thru the fuse box cover but it is helpful to pull the trunk light ( same side) so you can look down and see where to grab and release the plug. Just tie it up and you are all done.
No more Stop / Start function on your XE.
Old 04-18-2017, 11:31 AM
nuke986's Avatar
Default I did it
Illuminate trunk near fuse box (I parked my car with the trunk facing the sun)
open the fuse panel and look through the space between the trunk door hinge and the trunk side panel down into the fuse area (you should now see the plug)
The tool a thin standard flat blade screw driver
The locatoion, up in here.
The plug, after it's out looks like this.Put screw driver blade where arrow is with one hand and pull plug with other.
Bam, NO more start/ stop
The following 6 users liked this post by nuke986:
BigCat09 (04-20-2017), Charles Calthrop (04-19-2017), Jaguilar (06-28-2017), lifted.n.lowered (03-31-2021), ololly (05-08-2017), whoisbigman (05-08-2017) and 1 others liked this post. (Show less...)
Old 04-18-2017, 07:29 PM
Thumbs up
Nice bypass.
I'll be interested to see if the BCM/GWM (Body Control Module/Gate Way Module) sets any DTC's (Diagnostic Trouble Codes) with the plug disconnected.
I'm guessing disconnecting that plug inhibits the shutdown signal to the PCM (Powertrain Control Module) , and is probably where the tow package module is plugged into, if the vehicle is so equipped.
But I could be wrong and I often am.
Just ask my wife.....
Old 05-08-2017, 08:03 AM
whoisbigman's Avatar
Done... Thank you nuke986 for the pics...
Old 06-29-2017, 08:35 AM
Jaguilar's Avatar
Smile
On my XE cat, I did the "no need to turn ECO off" anymore process yesterday and it works well. I would add to the process: a small light and a mirror. The mirror helps you see inside where you need to press the connection with a small tip flat head screwdriver.
Best regards
dinop
06-14-2016 02:48 PM
Jaguar Forums Editor
Jaguar Press release
04-12-2016 05:48 PM
haroldleggett
F-Pace (X761) / C-X17
04-08-2016 11:13 AM
haroldleggett
XE ( X760 )
04-08-2016 11:11 AM
aquill1
02-07-2007 02:41 PM
Quick Reply: Eco On/Off and Secondary Battery?
