XE ( X760 ) 2015 -
Ultimate XE LED Thread W/Pics
Old 01-20-2017, 01:15 PM
RaffiNJ's Avatar
Do a build model and go base for 3 series, A4,A3, C Class, S60, S80.... all start off with Halogen lights. It's just that in you locale, the dealer may not be ordering stripper models for the lot. Around Boston, it is more common to see base model from any of these marques as everyone drives these. Our Volvo S60 AWD is a base model optioned only with metallic paint and heated seats... That's the way they order them to create volume and good lease deals.
Yes I see your point I think one reason I got stuck with this is its the V6 Premium so the base model. You would still think for a 47K car they would put on the better lights and put the cheaper ones on the lowe end 4 cylinder models. I was expecting the whole time to get the better lights and didn't realize this until getting home but I guess you cant win them all. Had I knew I might have opted to pay a bit more at another dealer but I am still happy. If I can only find the white/blue bulbs it should all good.
Old 03-05-2017, 02:34 AM
babyjag91's Avatar
Hey BigCat, just wondering how the ambient lighting project is going. I just realized the Prestige trim has available interior mood lighting. Now I want to go to my local dealership to see if they have a Prestige trim and climb underneath the dash to see what's going on
Old 03-05-2017, 05:53 AM
BigCat09's Avatar
I haven't had time to look any further. Soon as I get some free time i will try to investigate more.
Old 09-10-2018, 09:43 PM
its vish's Avatar
This link doesnt work anymore and none of the pictures on this thread are loading for me for some reason. Can you please send me a link as I am desperately trying to do these upgrades!
Old 09-13-2018, 12:37 PM
mosesbotbol's Avatar
Received 1,197 Likes on 931 Posts
FWIW, I had had an XE loaner with the halogen lights and there was not much difference between the two. Maybe where it's pitch dark out, but where I drive at night (suburbs) I didn't notice a difference where I felt I needed the HID's.
Old 02-24-2021, 04:43 PM
WotWombats's Avatar
Hi BigCat, just wondering if you might be able to re-upload the pictures to this post when you have a chance? It seems you have the definitive thread on XE LED upgrades.
Thanks!
Old 03-03-2021, 02:34 PM
In this picture, when do the yellow highlighted lights turn on?
I think the lights in the yellow squares activate for the low-speed turning side light.
  #28
Old 04-01-2022, 10:01 AM
BritCars's Avatar
Lots of great intel in here on LED upgrades. Two questions that I couldn't quite see the answers to:
1) What LED bulb is appropriate for the trunk light? My owners manual says it's a S10W bulb, but I can't find out what that is. It's 10W so it's not the same as the T10 or similar 5W ones used elsewhere. Looking for something bright as the trunk is v hard to see in...
2) Has anyone successfully replaced the front side-lights (small square between the front headlights) with either an LED or a brighter/whiter standard bulb? Saw lots of comments that most bulbs are too wide to fit; and a comment that they are too close to the headlights to be able to use LED (get too hot?). Any guidance welcome (incl specific bulbs that have worked - and lasted...)
Old 02-08-2023, 02:39 PM
Qais - XE's Avatar
Default Glove Box dome light not working after replacing bulbs
Dears,
I changed footwell, glove box and trunk bulbs to LEDS it was working fine for a while. But now the center and rear dome lights switch on only when I open the door but dose not respond when touched as well as the glove box light.
I switch back the old halogen bulbs and it is still not working.
Is it a fuse ? I could not locate the correct one I tried the manual and diagram in side the fuse box but I couldn’t locate it.
please help if you know what happened
BigCat09
02-21-2021 01:48 AM
Jdrasp
05-05-2018 08:11 AM
Thermo
11-29-2015 10:34 AM
TheWarlock
03-17-2015 08:25 AM
myexcursion
07-01-2014 02:02 PM
Quick Reply: Ultimate XE LED Thread W/Pics
