Intermittent problem with car starting
Hi,
I'm a new Jag owner. I bought a 2010 XF about 3 weeks ago. I named him Mr. J. It's a great car and love it. But, it seems to have a little problem. Twice now I've driven it somewhere and when I got back in the car it wouldn't start. It cranks but won't turn over. Both times, when I first started it, it started strong, no signs of anything. But once I parked and came back, it wouldn't start. Both times I got a jump and once I got home, I turned the car off and started it again with no problem.
Has anyone dealt with something like this before? I'll be taking it to be looked at next week because I was advised that with the warranty I bought, if I tried to get anything fixed before 30 days it would be considered a pre-existing condition. In the meantime, I'm looking for some insight from veteran Jag owners.
Any help would be greatly appreciated.
Thank you.
Thank you.
My 2010 also had issues every year I owned it with the battery.
The early XFs are very hard on the battery. I ended up have to replace it every year.
I was lucky that it was under factory warranty and they always replaced if free of charge.
If I were you, I would take it to a good shop and have a high quality battery installed that has a 24 month free replacement warranty.
Received 3,114 Likes
Strong chance the battery is on the way out, XF batteries are notorious for going weak/faulty after around 4 years old, and you could still have the original 6+ year old battery.
First check the battery condition, and if not totally stuffed put it on a trickle charger overnight then see how it goes for a few days.
But if it is the original 6+ year old battery I would replace it anyway before you have more problems.
William, I noticed your car is a 2010 (LED mirror turn signals), but your sig shows your engine size as 4.2, are you sure you don't have a 5.0? the 5.0 AJ 133 was standard for 2010.
