Sat radio presets
Old 11-29-2010, 02:16 PM
chairman25's Avatar
Default Sat radio presets
I have a 2010 XF Premium. Periodically all of my presets go back to "weather". This has happened about 6 times and doesn't seem to be related to cold or warm weather. Has anyone heard of this happening? Did a search and could not find any information.
Is my unit defective or is there a software update that is needed?
Thanks in advance.
Old 11-30-2010, 03:47 PM
Post Sat Radio Presets
Yes mine has done it once, last month, strangely enough the original presets were in the system when I advanced through the steering wheel controls, but the display only indicated weather. I think it may be attributed to Sirius satelite radio, a clich!
Old 11-30-2010, 07:48 PM
bcantr7's Avatar
I have seen quite a few with this problem. There is a bulletin out for a software update of the satellite radio module. Just take it up to your dealership and have them take care of it for you
Old 12-01-2010, 11:23 AM
chairman25's Avatar
Thanks for the info. The car has to go in for a rear window that does not always want to stay up and to have the winter tires put on.
Old 12-05-2010, 08:59 PM
herter's Avatar
check the manuel about resetting the rear windows. You should be able to reset this yourself.
Old 12-16-2010, 11:00 AM
chairman25's Avatar
OK got the TSB performed on the car, I'll see if it really worked. Keep you posted
Old 12-18-2010, 10:48 PM
djlloyd's Avatar
Yes. The update fixes the rear window "bounce" issues, satellite radio preset issues, and has "other entertainment system updates."
Paora
02-04-2021 12:36 AM
oldjaglover
04-01-2020 05:04 PM
philwarner
01-31-2016 09:36 AM
ziondio
09-28-2015 11:24 AM
Quick Reply: Sat radio presets
