upper control arms.
upper control arms.
so I looked around here first to see if I could find an answer, couldn't. I need to change my upper control arms because my ball joints at F*****. thanks Hawaii roads. I cant seem to get the bolts that hold the bushing in, out. the just hit my springs/shocks. do I have to remove all of the suspension to get these simple things out?!
But generally the shock and spring assembly need to come out to remove the upper control arm bolts.
Received 3,126 Likes
I believe I disconnected the shock mount from the top to allow it to move enough to remove the two bolts. As for the bolt joint, I just let the suspension pull and used a pickle fork.
The hardest part on the passenger side was getting to the nut that's inside the engine Bay under the fuse box on the firewall side. I used a telescoping magnet to stop it from falling on removal and install.
If you research s-type jaguar it's the same set-up.
I spent a solid day changing my upper arms..........was actually swappingvthe upper arm bushes for poly versions which I highly recomend, really tightens up the front end feel and noticed no difference in nvh.
was a nightmare job though as si many parts have to be removed........plenum, fusebox, water resevoir, shoks top and bottom bolts.......good luck
