Your 2 cents...
Your 2 cents...
Ok... in short I have an engine noise going on for 3-4 months now in my XFR. I have 3 cars excluding kids and wife's , so I swap often. I finally decided to have it looked at in December.
The dealer said it was timing and wants $6-7k. I never had a CEL, codes, performance restrictions or performance issues.
The indi said it's not timing or I would get codes, and didn't think it sounded like the timing. He said I can swap the timing, but that noise will probably still be there ...and you are short $4k.
Who's advice do I take??
Received 3,126 Likes
Originally Posted by a6kmita
Are you referring to the rhythmic "knock" that you can hear in the videos or the background "rattle" that you can also hear?
Well if it's been ongoing for 3 or 4 months it's a slow burn thing and not catastrophic-- yet.
I would tend to give it over to the indy. It sounds like he's more willing to try to isolate the problem rather than just replace the 'timing'- (and I'm not sure what the dealer means?- the timing is electronic so all the pulleys and belts and tensioners?)
... and give up 4 gorillas when there are no fault codes and it's unsure whether it's the problem.
Yeah but the indi said he didn't think it was timing. If that proves to be the case then both quotes are null and void.
Seeing you'd be saving 2 grand even if it is timing with the indi, I'd get him to find what the problem really is first.
Caveat is whether the indi has a good reputation for technical prowess- only you know that or can find that out.
The indi is JagMac in Dallas and only works on Jaguars like the dealer. He took me inside and showed me an engine that blew, bc the guide rails slipped into the lower timing gear. This only freaked me out more.
He doesn't think there is a problem and said drive it until the CEL comes on.
My fear is the guides slip or it jumps time, and the cost jumps to the stratosphere.
I'm going to remove the drive belt and see if it's one of the pulleys or water pump. I also bought a Bluetooth code reader so I can watch for codes as I drive.
My gut tells me it's tied to the fuel pumps timing gear/chain or the water pump echoing inside the valley.
