Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ X300 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ X300 / XJR 1995-1997
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
97 XJ6L stalling on idle???
LinkBack Thread Tools Search this Thread
Old 10-26-2007, 10:30 AM
legalian
Guest
Posts: n/a
Default 97 XJ6L stalling on idle???
Doh, just bought a 1997 XJ6L which was in beautiful cosmetic condition (despite 110,000 miles). Drove it back from SC to Washington DC and handled great. The next day it stalled twice in traffic. I was hoping this was a fluke. Started the next morning, and about every other time I come to a stop in traffic the rpm's shut down and the car stalls. It starts right back up if I put it in drive, but then when I go to the next light it dies again. The battery light generally comes on as it dies and occassionally the transmission light even comes on. They generally go off when it restarts, so don't know if that's justa fuse. So basically any time I don't have my foot on the gas and am at a low speed it seems to die. Not sure if this could be a fuel pump or alternator. The electronics on the car still work when it dies.
Help! I'm hoping I didn't buy a lemon.
Old 10-26-2007, 10:50 AM
Cadillac's Avatar
Default RE: 97 XJ6L stalling on idle???
Nope, not lemon hopefully
Well, basically it should be something related to the idle sensor .Do you have any fluctations to the RPM ? I had some fluctations on my XJ40 and occasionally stalled . I had it serviced by Jag Specialist and the problem turned out to be a dirty idle sensor or some throttle body part . They cleaned it all and put it back .And voila
__________________
NITROUS OXIDE
Tutte Le Strade Portano A Roma
CHRONOMETRIC PRECISION
If You Drive A Porsche Boxter in Red, You're Unpleasant -Henry Cole
Old 10-26-2007, 11:01 AM
legalian
Guest
Posts: n/a
Thanks Cadillac,
From what I can derive throttle body build seems to be a common thread, bad MAF sensor or idle sensor as well. Do you think this is something worth taking to a Jag dealer to fix or can a regular garage handle something like this.
Old 10-26-2007, 11:37 AM
I'm with Caddi. I would try the idle control valve. Alternator can be tested in the car at any Autozone. I would start there and rule that out first. Does the alternator light come on before you die or after?
__________________
Ken Karr
Old 10-26-2007, 11:59 AM
Cadillac's Avatar
You're welcome and happy with ken's corrections
It's up to you , the part I had it cleaned wasan expensive oneand I don't think official Jag dealers would bother to clean it off . They just replace it
__________________
NITROUS OXIDE
Old 10-26-2007, 12:00 PM
legalian
Guest
Posts: n/a
No alt lights just come one, just the battery and sometimes the transmission light (which really throws me for a loop). All the electronics works, even when it shuts off. So hopefully not the alt as that'll be $600 or more to replace I'm sure. Lead culprits, so far, throttle body build up, idle sensor, MAF sensor, ECM or BCM.
Old 10-26-2007, 12:09 PM
Send a message via Yahoo to bigdreams05
$600 ????? WTF? No way man. I can get it remanufactured for like 50 bucks, plus shipping. The downside is the downtime which is basically shipping. BTW, my response is posted in the other forum. Find out what the price of the alternator is and let us know, because $600 sounds rediculous.
__________________
Quote:
ORIGINAL: My Mother
"Haven't I told you "A MILLION" times NOT to exaggerate"
Old 10-26-2007, 12:14 PM
legalian
Guest
Posts: n/a
My estimate was probably off, I know I have spent $300 or so on previous cars like my 300ZX and was just trying to adjust for Jaguar. Like I said, I'm guessing it's not the alternator anyways. But we'll see when I take it to the shop. I live in Washington DC anyone know of a decent garage around here. I have a decent mechanic but don't know if he knows much about jags, and I definitely don't want to go to the dealer.
Old 10-26-2007, 01:20 PM
Battery light: ok. Take and have the battery load tested. If the battery is having problems it will shut the car down. The alternator may be doing fine, but if the battery is weak the computer will freak out. The computers require a constant voltage stream and the alternator is too irregular to power them. A bad battery maybe the only problem. I hope it's that cheap and easy!
__________________
Ken Karr
Old 04-12-2011, 03:21 PM
Had a stalling-at-idle problem with my 1996 XJ6 at about 85,000 miles. A new EGR valve (new-in-box, $30, ebay) fixed it. If I hadn't found a new one so inexpensively I probably would have tried taking the old one off and cleaning it before giving the Jag dealer big bucks for one of his new ones.
Tags
1997, 97, air, battery, causing, flow, idle, jaguar, mass, pump, pumping, sensor, stalling, stalls, weak, xj6l
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
