Air Intake temperature sensor - readings above 200F
Old 02-10-2015, 12:18 PM
AlbBolivar's Avatar
Default Air Intake temperature sensor - readings above 200F
The past few days my air intake temperature readings have been averaging about 212degreesF with an ambient temperature of about 70degreesF. My engine temp readings seem to be ok at about 178degreesF but I'm not sure why the intake temps are reading so high. They use to read at about 130degreesF before. I thought that maybe just cleaning my MAF sensor would work but today on my way to work I was still getting high readings. I am running an aftermarket oil k&n filter, would this be the issue?
Anyone have any ideas what it could be? This is on my 97XJR btw and I know the part numbers differ slightly from the XJ6 MAF and the XJR MAF
Old 02-11-2015, 12:41 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
I would give the MAF a good cleaning and see what you have, but my guess is that your MAF is shot.
Kevin Burnaby
06-28-2020 08:04 AM
cissdm
05-03-2016 06:02 AM
KarimPA
09-12-2015 08:15 AM
tberg
09-07-2015 07:32 AM
KarimPA
09-03-2015 07:32 PM
Quick Reply: Air Intake temperature sensor - readings above 200F
