Door speaker size...the last thread???
Old 02-24-2014, 10:26 PM
JTsmks's Avatar
Default Door speaker size...the last thread???
So I'm getting ready to do my door speakers and I'd like to have them in hand before I pull the door "cards" after searching the Forum I've come to the conclusion that they are 5.25", 6", 6.25" and even 6.5" but never a definitive answer. Has anyone out there recently replaced there's and have an accurate measurement, brand, model etc so I can get this right in one shot. Not looking for super sound quality just no "crackle" from these 97 dried up speakers.
Old 02-24-2014, 11:35 PM
AlbBolivar's Avatar
They're 6.5" speaker holes. At least that's what fits perfectly in my doors.
Old 05-10-2014, 07:15 PM
al_roethlisberger's Avatar
Seems consistent with the other "speaker" threads that a 6.5 inch speaker will fit.
Two other questions come to mind though:
1) Has anyone verified the stock speaker impedance? Is it 4, 6, 8 or 16 ohm? I would suspect 4 ohm being an automobile speaker, but...
2) Does anyone know if there are any depth challenges with the door "woofer"? Will most standard depth 6.5 speakers work fine, or are shallow depth models required to clear anything inside the doors like window lifts, etc?
Thanks,
Al
Old 05-10-2014, 10:44 PM
doc's Avatar
doc
doc is offline
These are what I fitted to my XJR6 direct fit no messing about cant go any bigger than 6 inch without serious modifications
JL Audio TR600-CXi 6" Evolution TR Coaxial Car Speakers
If you search around there are cheaper places to buy them
I chose these on the sensitivity rating the higher the sensitivity rating the less power needed to drive them
they sound okay not much bass but that's to be expected for a 6 inch speaker
I use this head unit Alpine Electronics of Australia
don't need a CD got so many Ipod's and my CD collection over the years is over a thousand CD,s
I figured I bought them because I liked the music just loaded a giant compilation on one of my Ipod's select random takes from Home to Melbourne and back before I hear the same song about 36 hours
Used this amp http://www.sonicelectronix.com/item_...X4.htmlhttp://because I fitted this sound expander
In the end its pretty good just lacking in the bass got these to go into it when I get a chance
 Amazon.com: Aura AST-2B-4 Pro Bass Shaker: Electronics Amazon.com: Aura AST-2B-4 Pro Bass Shaker: Electronics
My newXJ8X350 has a much better speaker system from the factory about time all I had to do to it was fit an I pod adapter which was quite expensive but able to use my Ipods means I can take my music to all my cars don't like to listen to the radio if I want guidance and talk Ill take the wife LOL
al_roethlisberger (05-10-2014)
Old 09-12-2014, 03:06 PM
imagineaudio's Avatar
I'm bumping because all 4 of my door speakers have rotted. I replaced one with a used speaker from another car just to see how long it would last.... 2 months, turns out.
So what aftermarket speakers will be a direct fit? It seems 6.5 inch speakers are the way to go. I'm a little skeptical of installing coaxial speakers as its already a component system with tweeters mounted separately. But I can only find either coaxial or component systems with the unnecessary extra tweeters...
I'm also a sound guy by trade, so decent sound is a must. I won't be replacing the factory head unit (standard base model) and I understand it's a bottle neck in overall sound quality, so I don't want to go overboard on speakers.
Thoughts?
Old 09-12-2014, 05:55 PM
Can't give you a definitive answer, but if I were looking for a single component speaker I'd start here:
Parts Express: the #1 source for audio, video & speaker building components
I've built a few home projects from various components, including individual drivers of various sizes, impedences, etc. from them.
Looks like they have about 20 different 6" drivers in their "Professional" speaker section alone.
Might be some options there or from similar vendors. I wonder what the impedence is for the stock Jaguar door speakers in the HK system?
Old 09-12-2014, 06:51 PM
aholbro1's Avatar
Received 1,638 Likes on 1,066 Posts
Discontinued, but I put four of these in w/stock head unit, non premium sound a few years ago. Direct-fit/no muss, no fuss. They included a little jumper so no wire cutting, either. Suit me, sound fine.
Kicker DS60 6-1/2" 2-way car speakers at Crutchfield.com
Old 09-12-2014, 07:22 PM
groutby's Avatar
Default I installed 5.25"....straight fit...........
To all doors of our '96 X330, as advised by our local car audio guy,(who suggested most "Euros" of this era used 5.25"), plenty of depth to install too over the "stock" speakers...very happy with the result, but suspect you can "shoehorn" something larger in there if you really want to. Nothing spectacular about the sound but as stated: "better than the crackly original ones"...
Old 09-13-2014, 05:32 AM
doc's Avatar
doc
doc is offline
The bass from 6 inch speakers are pathetic so I could only imagine what 5.25 would be like
If you don't mind doing some work a set of 6x9 in the rear deck would work nicely then some bass blocking caps for the door speakers still not perfect I gave up on my XJR6
The sound system in the X350 is light years ahead of the X300 cars and it's a compromise as well
Old 09-15-2014, 05:02 PM
Thanks for the parts express link, looks like a good resource... Anyone know off hand what resistance the oem door speakers are? 4 ohm or 8? ...and what depth? I remember it being pretty shallow the last time I was in there...
Old 09-15-2014, 07:45 PM
Haven't seen any confirmation of impedance, but you could figure it out if you have a stock speaker by putting an multimeter on it.
Old 09-15-2014, 10:36 PM
aholbro1's Avatar
The replacements I used were 4 ohms and they worked just fine. I'm no audiophile. Have no idea what the originals were, but I suspect there may be some performance issues if I'd replaced 8 ohm with 4 ohm, all around. So I'd reckon the original offering was 4. I've got some busted originals out in the shop, I'll see if it is printed on 'em anywhere tomorrow evening...
Old 01-24-2015, 08:17 PM
I'm going to give these a go: Kenwood KFC-C1655S 6.5" Sport Series Flush Mount Car Speakers
I chose them because:
Flush Mount ?
4 ohm
35watt RMS (good match to stock head unit?)
Shallow
lots of mounting holes
Cheap
Any obvious reason they won't work?
EDIT: upon further inspection it looks like these are intended to be top mounted to the surface...
Old 01-24-2015, 09:02 PM
aholbro1, I found some of those kickers in stock, did the mounting holes all line up? Did you put some sort of spacer on between speaker and mounting surface? It looks in the pictures that the surround protrudes past the edge of the metal frame....
Old 01-28-2015, 12:03 AM
journeyman's Avatar
This came from the driver's door on my 96 VDP. It is labeled 4 Ohms and measures 3.6 Ohms on my multimeter. I measure 6.25 inches in diameter and it's a very snug fit in the door opening.
al_roethlisberger (02-04-2015)
Old 02-02-2015, 02:49 PM
Thanks for the pic. I finally pulled one and have the same sticker, and tested the same resistance.
I'm wondering what the frequency response of the speaker is... All mine are blown so can't measure.
Old 02-04-2015, 10:16 PM
So it looks like the front speakers are typical 6" speaker size if they measure 6.25 actual.
Are the front and rear door speakers the same size?
For some reason I was thinking I read that the rear door speakers are smaller??
Old 02-05-2015, 06:10 PM
It's the same part number for both front and rear doors.
I still haven't pulled the trigger, but I'm now thinking of trying these:
Dayton Audio RS150-4 6" Reference Woofer 4 Ohm
Wonder what the frequency response of the tweeters are.... If they go down to 2.5khz, should be a good match.
Old 02-05-2015, 09:42 PM
Well, since the cover on my rear LH door tweeter is broken, I can try to take a look tomorrow or this weekend. As I recall there is simply a capacitor on the tweeter, so it is likely a very basic high pass filter right on the tweeter.
Old 02-06-2015, 08:07 AM
countyjag's Avatar
Guys,
as I write, there is for sale on UK ebay (I am not the seller by the way!) a set of Harmon Kardon door speakers for the X300, together with the wiring loom and the amp, all for £90.
There does not appear to be a sub woofer for the rear window shelf, or tweeters, but it would be a good and cheap way forward, preserving originality at the same time. My 1996 XJR has the Harmon Kardon system, which is still in full working order, and while it is no ghetto blaster, it delivers excellent sound and compares well to the system in my 2011 Range Rover.
P.s they are listed under "jaguar/Daimler X300 premium door speakers"
kevinl
10-31-2019 06:15 PM
mbergen
10-23-2019 10:26 PM
Dz1rfj
07-17-2018 10:29 AM
Dz1rfj
09-16-2015 03:44 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Door speaker size...the last thread???
