Error Codes P1315 and P1316
Old 11-24-2010, 09:19 PM
jhxj6's Avatar
Default Error Codes P1315 and P1316
My check engine light has been on for a few weeks so I went and got my codes read. It gave off two error codes: P1315 and P1316.
P1315 - Persistent Misfire
P1316 - Injector Circuit / IDM Codes detected
I'm no expert and I don't know what IDM codes are. What could be going wrong to throw off these codes? Also can someone please tell me how to see the IDM codes if thats possible or what to do about them? Could changing spark plugs stop the misfire?
Thank you for any help and advice in advance.
P.S. I was able to find about ALL the codes at http://www.jaguar-online-club.de/obd...t_codes.0.html
________
Pregnant Lesbian
Old 11-25-2010, 09:27 AM
Received 7,879 Likes on 4,763 Posts
Here is the Jaguar DTC Guide for your car
The ECM is detecting a misfire
bob gauff
File Type: pdf
Old 12-04-2010, 07:30 PM
jhxj6's Avatar
the p1316 code is misfire and excess emission. the p1315 is a misfire in one of the cylinders and the injectors switched off. The possible causes are the same as the p0300 code which are:
Fuel contaminated
Fuel injector(s) blocked or leaking
Ignition secondary circuit breakdown
(coils, spark plugs)
Fuel pressure low
Cylinder compression low
Broken valve spring(s)
CKPS circuit fault (CKPS DTCs also flagged)
Fuel injector(s) circuit fault(s)
(Injector DTCs also flagged)
Ignition coil primary circuit fault(s)
(Ignition coil DTCs also flagged)
how and what tests should i run to start cutting out possibilities.
________
THREESOME LESBIAN
Old 12-04-2010, 07:46 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Well, do you have any symptoms? Can you feel a stumble either at idle or while accelerating? Actually , these cars are slow to give these codes, with most people reporting feeling a misfire without getting a code. If you are not feeling it, I would reset and see if it returns.
Old 12-06-2010, 12:00 PM
jhxj6's Avatar
I reset the codes on thanksgiving day so I will check them again soon. When I start the car it emits a loud noise that I believe is the sound of a pump or something over the engine that only lasts for a few seconds. Some people have told me a timing chain but I have been hearing the timing chain rattle for a long time before that and on the times that it doesn't make the new sound I can still hear the timing chain. There was one day that it almost didn't start then drove horribly. When I was driving the car would have a hard time dropping rpms and I would almost have to stand on the brakes to stop it. Next time I turned it on it didn't happen. However my power steering pump is leaking so I thought the sound might be my pump
________
****TUBES
Old 12-06-2010, 09:25 PM
You have a bunch of unrelated faults but they are all common.
Here is the TSB collection I found for you
bob gauff
File Type: pdf
File Type: pdf
Old 12-08-2010, 06:31 PM
jhxj6's Avatar
today it started shaking really bad upon idle and a little while driving. check engine light started flashing simultaneously with the shake and it pulled 4 codes when I brought it by advance auto parts. P0301, P0302, P1316, and P1313
________
Healthy Relationship Advice Forum
Old 03-07-2021, 09:30 AM
Simar's Avatar
Default P1315
Fuel contaminated
Fuel pressure low
________
THREESOME LESBIAN
hey boss i got p1315 code in morning just wanna know can i still drive the vehicle or i have to tow it ?
Old 07-17-2022, 01:10 AM
Gursandhu's Avatar
Default Engine misfiring.
I was heading to my friends house when suddenly the engine light was turned on and when i parked my car it started vibrating and misfiring later diagnosed with obd2 and recieved code p0305 and p1315 on my 2017 xe. The vibration is greater when the car is in reverse or when idle or when i accelerate and I can feel power loss in between. Am not fully sure about the actual root cause can somebody help me. I did changed the engine oil filter it still is the same and there wasn't much loss of previous engine oil.
Old 07-19-2022, 10:49 AM
Vee's Avatar
Vee
Vee is offline
Received 1,510 Likes on 1,176 Posts
Looks to me like you have a problem at Cylinder 5.
1. Check for oil in cylinder. (easy check for failed gasket)
2. Replace Spark Plug. (remove spark plug and make sure it's ok, replacements are so cheap, so I wouldn't reuse the old plug in any case)
3. Replace Coil (no good way to test, if #1 and #2 don't resolve the issue, this is the likely and most expensive repair)
Those are your most likely fixes.
Gursandhu (07-19-2022)
Old 07-19-2022, 10:57 AM
cdma's Avatar
If you need a coil, I have a lot of them and can send you one if you just pay for shipping. Just let me know
Old 07-19-2022, 11:02 AM
Gursandhu's Avatar
thanks alot for that but i already have ordered spark plugs and three ignition coils ...but if i do need more i will let you know . Hope spark plugs will fix the issue since one of the spark plug is little black on top and i feel like it's cause of ignition coil since there wasn't much of fuel on the plug and there was very little that i can understand that spark plug wasn't working and the fuel in cylinder 5 was not burning but let's hope for best.
Old 07-19-2022, 11:07 AM
Gursandhu's Avatar
yeaa i did opened the spark plugs and one of them is black just clean black. And there isn't much of oil either maybe it's a ignition coil but will get to know once the parts arrived.
This ones good.
See this one i feel like it's one from cylinder 5 since i can't really tell which cylinder is which and it isn't written on manual either.
Old 07-19-2022, 01:49 PM
Vee's Avatar
Vee
Vee is offline
Failed coil isn't unusual. I believe Cylinder #1 is the one closest to the front, #6 is the one furthest back.
Old 07-19-2022, 01:50 PM
Gursandhu's Avatar
but it has like three cylinder on right three on left 😂
Old 07-19-2022, 02:07 PM
Vee's Avatar
Vee
Vee is offline
I'm assuming you are driving the AJ16 engine?
Old 07-19-2022, 02:29 PM
Gursandhu's Avatar
it's a 35t xe rsport 2017.
Old 07-19-2022, 03:02 PM
Vee's Avatar
Vee
Vee is offline
Why are you in the x300 forum?
Old 07-19-2022, 03:05 PM
Gursandhu's Avatar
honestly new on this website don't know much lol.
Old 07-20-2022, 11:49 AM
labcoatguy's Avatar
Yes, we can tell. You're much more likely to find answers in the correct forum, which is here. https://www.jaguarforums.com/forum/xe-x760-85/
Rnanc44
01-15-2020 10:37 PM
GeorgiaXJ8
09-05-2018 12:01 PM
Gblauf
03-03-2013 09:36 AM
GermanGoodness
06-17-2012 02:23 PM
Jessy
05-25-2010 09:42 PM
Quick Reply: Error Codes P1315 and P1316
