Front Turn Signal Bulb replacement?
Hi Guys
It's been a while since I have been here, So I have a question I need help with.
I need to replace a blown front RH amber turn signal bulb but the problem is I have forgotten how to access the Assembly. Can I pull it from the front?
Any suggestions. I have to access the assembly to replace the bulb.
I have the XJ300 1997 not the XJ 308
Thanks in advance
BBR in Dallas
Thanks in advance
BBR in Dallas
Unless I'm mistaken, I have changed a front indicator bulb, by simply reaching up behind the lamp and giving the bulb holder a twist and pull, but if you want to remove the lamp holder assembly, it will unclip easily enough.
Just insert a flat blade, like a standard dinner knife, into the space between the fender and lamp holder on the inner side, that is, nearest the grill. This will depress the plastic tang, allowing you to withdraw the assembly as the tang on the outer side is fixed, more of a tab I suppose.
Pull the assembly outwards at the knife end, using the knife for encouragement and refitting is the reverse, fitting the outer side in first.
Hope this helps.
Hope this helps.
Hope the lamp works out and Season's Greetings to you and yours also.
Front RH Turn Signal Replacement
Hi
well I managed to pop the lens out to day......... It can only be accessed from the front because of the metal bumper/fender blocks access from behind. That been said I removed the bulb holder from the housing. It is retained with a screw. I then checked the bulbs. Only one flashed. the 2nd was not working. I swapped the bulbs over by reversing them, and found the changed bulb did not work. So the problem is not a "Blown Bulb" but some other electrial fault.... So if anyone has any ideas I'd love to hear from you......... I did check the wiring and everything seemed to be fine..........
Thanks in advance
BigBossDallas
Thanks in advance
BigBossDallas
BigBossRadio (12-26-2014)
THANKS FOR THAT I will check that out tomorrow.............. It was beautiful here today till the clouds rolled up from Mexico.......... and the sun went down.................... Now its cold again....................... Reminds me of when I was a child In the back seat of my dad's car driving from waterford to Abbeyfeale....... in west Limerick to visit my grandmother............ Damm those were the days............. Thanks for the insight........ Nollig Sonagh Guit.................... Well the spelling may not be right but you get the idea.........
Wiring harness?
Hi
Thanks in advance
BigBossDallas
Thanks in advance
BigBossDallas
Front Turn signal/Indicator Problem
Thanks for that insight............ I will take a look at that over the weekend.......... .......... I did check the bulbs in the offending RH "Turn Signal/Indicator" While only one of the two bulbs flashes I did check each bulb and both are good. It's just that only one of the two flashes......... thus leading to "Rapid Flashing" of the RH Turn Signal............. The problem is annoying and I need to correct it........... I may need to take off the front fender (which I have done before in the past to make repairs) and take a closer look at the wiring............
So if anyone has any bright ideas I'd love to hear them..
Thanks eyeryone and a "Happy New Year" to Y'all
Tony K
03-26-2024 01:53 PM
philwarner
12-06-2021 07:13 AM
