sunroof/moonroof
Old 02-13-2012, 10:45 AM
Simprof's Avatar
Default sunroof/moonroof
Is there anyone on the forum who can tell me of a place where I can get a replacement sunroof/moonroof rubber seal. Mine has dried out and is now starting to leak..
Old 02-13-2012, 12:56 PM
Do you physically have gaps in the seal, like sections missing?? That seal doesn't really stop water from entering, it just keeps it at a manageable level. The tray then channels the water to the drains to be carried away. You may have drains plugged up.
A replacement seal has to be crimped with a special tool around it's entire perimeter to properly replace.
Cheers,
Old 02-13-2012, 02:38 PM
Received 7,862 Likes on 4,752 Posts
Here is a TSB for the special tool. It is a long painstaking process to replace and your hands get tired. The channel has to be bent correctly to accept the new seal. I guess after replacing several, you can become proficient and the task easier.
Take XJRGUY's advise and clear the drains.
bob gauff
Old 02-13-2012, 04:08 PM
Simprof's Avatar
Thanks guys the drains are all clear but the seal is realy dry.. I just wondered
Don B
General Tech Help
11-09-2015 12:59 PM
JagV8
09-11-2013 12:02 PM
awngo33
11-11-2011 02:16 PM
Cush
04-29-2008 02:07 AM
Quick Reply: sunroof/moonroof
