How much antifreeze?
Old 08-16-2013, 12:03 AM
rob20087's Avatar
Default How much antifreeze?
Hi, my 4.0l engine runs a little cool. So will change the thermostat which is the most likely culprit. May as well flush the system while I'm at it. So am wondering how many litres of antifreeze to add. Couldn't seem to find an answer searching the threads. Just another thing. Where are the bleed screws? Thanks. Rob.
Old 08-16-2013, 12:22 AM
trucknetjack's Avatar
there is one at bottom of rad,and on the block,read that they like a 50/50 mix others will give more precise details soon.
got to do mine soon.
Old 08-16-2013, 07:32 AM
aholbro1's Avatar
Received 1,638 Likes on 1,066 Posts
I belive it is a 12 system. So you want 6L anti-freeze. My radiator has no draincock. Could not find the block drain as shown in the pubs. I drained by disconnecting the lower hose. Got about 2 gals. Topped up with distilled and brought it up to operating temp. Drain/fill/run. I had "good color" after 10 gallons of distilled.
There are no bleeders.
The following 2 users liked this post by aholbro1:
rob20087 (08-17-2013), Timothy Thomas (04-08-2021)
ejjbee
01-26-2019 11:53 AM
drpsmith
10-16-2015 08:23 AM
Gregory Neil O'Rear
09-29-2015 09:52 AM
kevo
09-08-2015 09:45 AM
JanuarXKR
General Tech Help
10-14-2009 09:44 PM
Quick Reply: How much antifreeze?
