Radiator grill badge
Old 10-24-2014, 09:43 PM
97x306's Avatar
Default Radiator grill badge
hello folks,
XJR hood and front grill is going to be painted (stone chips)
I have removed the radiator grill, but how do I remove the flat badge on the radiator grill?
It's item #10 in the attached picture.
The back has 2 little small sticks. The badge seems to be glued/bonded to the grill. No screws, no clips, etc..
Old 10-24-2014, 10:04 PM
shaune's Avatar
Hi, 96x300,
It is in fact held on by some sort of adhesive. Had mine off a few weeks ago to be painted from the mess made by highway debris. There's no other clips or anything to worry about removing first. When it came time to fasten it, I just used two-sided, outdoor tape strategically cut to fill the back of the growler prior to lining up the rear protrusions to the grille itself after paint was completed and sat for a week.
Old 10-24-2014, 11:14 PM
97x306's Avatar
oh I see, so it's glued.
how did you remove it without breaking it?
I tried to pry it off, but I didn't force it too much as it seemed fragile
Old 10-25-2014, 12:01 AM
shaune's Avatar
Use some fishing line (or something similar) to first break the 'seal' starting at bottom of badge. Side to side motions pushing upward til you reach those pins. Should be able to pry off at that point.
97x306 (10-25-2014)
Old 10-25-2014, 10:22 AM
97x306's Avatar
thanks Shaune
hoodun
02-20-2023 05:52 AM
sadepol01
02-08-2022 10:13 PM
Mac Allan
07-20-2020 05:46 PM
10 XF Premium
10-01-2015 12:47 AM
Quick Reply: Radiator grill badge
