rear end, differential or gear oil
Old 09-06-2011, 10:39 AM
pan84's Avatar
Default rear end, differential or gear oil
Hi its time to change oil in the rear oil, but I cant find info what kind oil its should be. it should be shell spirax super TS 90, but what is it, 75w90 or 85w140?
Thanks for any info
Old 09-07-2011, 04:35 AM
Received 10,312 Likes on 6,822 Posts
OK, you are up there and the specs we get down here sometimes do not transfer to your market, BUT, here goes.
Castrol Australia lists:
EPX 80W90, for NON LSD units.
LSX90 for LSD units.
Now being that the USA NEVER got thw mighty 3.2ltr engine, and my info indicates that the 4ltr cars ALL got LSD, I would go with the LSD oil.
Also down here, MOST gear oils are now LSD compatible, coz LSD oil will NOT harm a non LSD diff, but non-LSD oil, can reek havoc with a LSD diff. Good old Aussie common sense haha.
Old 09-07-2011, 07:16 AM
Doug's Avatar
Received 10,757 Likes on 7,101 Posts
I use 80/90 weight...whatever name brand is on sale that day. Shell, Valvoline, whatever.
I think it's the first time ever but I have to disagree with Grant. The only X300s with limited slip as standard issue were the XJRs. Those aside I think few USA cars ever had it.
pan84 (09-07-2011)
Old 09-07-2011, 07:40 AM
pan84's Avatar
so 80w90 will be ok? and I can put lsd additive
Old 09-07-2011, 09:01 AM
Thanks Doug. I was just not sure on LSD in the later cars.
Our '88 XJ40 3.6ltr had LSD, so I thought the big engine X300's would follow, obviously something else such as "traction control", took its place.
The 3.2ltr no got traction control, not enough Mumbo to need it.
Old 09-08-2011, 09:09 PM
pan84's Avatar
Never change gear oil on jaguar, it have drain plug on differential?
Old 09-09-2011, 01:08 AM
Doug's Avatar
Yes, drain plug on the bottom. The filler plug is on the rear cover, right of center, about 1/3 up from the bottom.
Don't drain the oil unless you're sure you can remove the filler plug :-)
Old 09-09-2011, 01:03 PM
smgdata's Avatar
Hey Doug, Im gonna fill mine in the next cpple weeks. That filler plug, any idea what kinda bit or wrench to use? Its just a giant square?
Old 09-09-2011, 01:06 PM
Doug's Avatar
Mine's a 1/2" square recessed type. Your's probably is, too
pan84 (09-09-2011)
Old 09-09-2011, 04:51 PM
smgdata's Avatar
Thanks!!
Old 09-09-2011, 06:57 PM
pan84's Avatar
Thanks Doug
Here is how I change gear oil https://www.jaguarforums.com/forum/x...-change-60513/
Old 09-10-2011, 07:14 AM
caldercay's Avatar
Thanks for any info
This is out of the Vehicle Care Manual (though it's not specifically stated for my 1996 year model - it's probably applicable to all x300 year models), Page 33:
Rear axle:
Refill - Spec: API GL5; SAE Visc: EP 90; Comments: Use only Shell Spirax Super 90
Top up only - Spec: API GL5; SAE Visc: EP 90; Comments: Alternative brands may be used when Shell Spirax is not available.
kelliott
05-31-2022 05:26 PM
RaceDiagnostics
09-07-2015 07:28 AM
obwoodie
09-03-2015 07:45 PM
OkieTim
09-02-2015 12:48 PM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: rear end, differential or gear oil
