Differential noise
Differential noise
Hi to all you great guys on this forum, I need some help, my differential is making a whining/whirring sound. I have checked the wheel bearings and they are good, so jacked it up put it in gear and gave it some gas and the noise is definitely from diff.Faster I go the higher and louder the sound,and the reverse when I slow down. So my question is....is it the actual diff gears that are the problem or are there some bearings in the diff that can be the cause? There is no clunking when I put it in drive and or reverse.Any help would be really appreciated as I am in South Korea and the diff would be an extremely expensive part to purchase, so am hoping there are bearings that cause this.
Received 10,746 Likes
The following 2 users liked this post by Doug:
al_roethlisberger (05-14-2018),
Brent (01-13-2013)
I agree with Bob Gauff. I had the same problem in 2010 with my DD6.
You can replace the pinion bearings, but it's expensive and it takes an experienced and well versed mechanic.
Make sure the garage has the Vehicle Service Manual (esp. chapter 9); if not: you should find the fee-based download here: http://jaguartechinfo.com/ or pm me.
And last but not least: correct pre-load is of high importance.
Good Luck!
Good Luck!
baskervillema
10-01-2015 06:43 PM
