code p0441 xj12
P0441 is for the Evaporative Emission Control System, which collects and stores fuel vapors, in order to burn them in the engine when the right time comes.
There's some info on this website about the EVAP system and this code.
In the Jaguar Engine Management Manual, P0441 is listed as: "EVAP System Incorrect Purge Flow"
The possible problems, in order of likelihood:
EVAP valve sticking
EVAP valve blocked
EVAP purge hose blocked or disconnected
EVAP canister atmosphere vent blocked
EVAP valve failure
AIR pump stuck ON
Chances are it's an issue with one of the EVAP purge valves, their wiring or hoses. There's one purge valve per bank on the V12.
Hope this helps,
Nick
EVAP valve sticking
EVAP valve blocked
EVAP valve failure
AIR pump stuck ON
Hope this helps,
Nick
philwarner
25
06-26-2021 05:43 AM
philwarner
09-05-2015 10:05 AM
