How to clear Stability Control Fail and ABS after removing central console panel Reso
Old 06-06-2013, 02:50 AM
Estilian's Avatar
Post How to clear Stability Control Fail and ABS after removing central console panel Reso
Hi guys. It's been a very long time since I've been online in here... I was abroad for 6 months and now back to my sweet home
So... here is my issue. Yesterday night I noticed that some of the bulbs on the central console panel (on the A/C control) are blown so I decided to replace them. I knew very well the procedure so it took me nothing more than 5 minutes to disassemble and assemble it back. The problem is that while on hurry I forgot to connect the wires for the Valet, ASC off and Locking buttons panel... then I started the car and I've got "Stability Control Fail" and ABS lights on. I realized my mistake, so I turned off the car, opened the console again and connected the cable back.
The problem is that now the messages are on all the time, even when driving the car. I have an OBDII diagnostic tool but it gives me "No pending or stored errors"... which is weird!
I remember that 2 years ago I did a similar stupidity with starting the car and putting on D to test for noises from the rear wheels while the car was lifted on a stand... and the ABS module lighted on immediately. Then I had the same problem with cleaning this error, but I don't remember what I did to fix it...
So... any ideas?!?! Besides it was a funny day cause I had drifting my Jag all day long on each turn with a good step on the acceleration
Old 06-06-2013, 04:22 AM
steveinfrance's Avatar
Probably a hard reset - remove battery earth lead and touch it to the +ve post
https://www.jaguarforums.com/forum/x...connect-74146/
Old 06-06-2013, 05:29 AM
Estilian's Avatar
This was the second thing to try after the OBDII... no luck with it.
Old 06-06-2013, 05:50 AM
Sounds as if you've got a real fault.
You won't see codes because the reader only sees P codes.
It seems a bit of a coincidence that this followed your intervention.
Are you sure you reconnected the right wires ?
Old 06-07-2013, 01:52 AM
Estilian's Avatar
Problem solved... by itself Today both errors disappeared while I was driving... I don't know how or why, but it's ok now
Old 06-07-2013, 05:42 AM
Funny old cars ain't they?
Forcedair1
05-14-2023 03:28 PM
Jpav27
07-31-2022 06:43 AM
cissdm
05-03-2016 06:02 AM
XFR_Gold
09-02-2015 12:24 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: How to clear Stability Control Fail and ABS after removing central console panel Reso
