2001 XJR 100k: P0300 P1316 P1111
Old 10-31-2011, 09:49 PM
Stevil's Avatar
Default 2001 XJR 100k: P0300 P1316 P1111
Started car up and suddenly it's miss-firing ... After .5 mile restricted performance came on, used my scanner and it returned ... P0300 P1316 P1111. Anyone have a similar tale ... I'm hoping it's just a coil or a spark plug. :/ Any help/suggestions greatly appreciated, thanks.
Old 10-31-2011, 11:17 PM
brgxjr's Avatar
My xjr was also miss-firing at one point and also got the restricted perf, and shortly after my fuel pumps went out. i dont remember the error code tho srry..hopefully it is a minor issue with yours. My tale turned into a horror story. I changed the fuel pumps and found out i most likely have a blown head gasket..good luck, lmk if you find out what the problem is.
Old 11-01-2011, 12:16 AM
Stevil's Avatar
I just tried it again ... now in addition I have P1642 P0305 P0306 P0307 P0308. I sure hope it's not the head gasket. Errors ... Fail safe, restricted performance, no asc no trac.
Old 11-01-2011, 02:38 AM
brgxjr's Avatar
Im pretty sure my miss-firing issue was a separate one frm the head gasket, although im no mech.. im sure someone on this forum can give you some good feed back. How is your idle at start?
Old 11-01-2011, 03:49 AM
test point's Avatar
Received 1,110 Likes on 932 Posts
All the codes are pointing to the left bank, all cylinders. Neither individual coils or a blown head gasket should invoke all cylinders. Fuel is a common link, contaminated, pressure or blocked injectors. A fuel pressure test is a cheap place to start.
There is a OBDII code list in the FAQ sticky at the top of the XK8/R forum. I would suggest resetting all codes and see what comes back up.
Old 11-01-2011, 06:05 AM
yeldogt's Avatar
I would agree in resetting and see what codes come back first -- make sure you don't have any problems with the intake that would be causing a vacuums leak.
Old 11-01-2011, 08:37 AM
Received 7,878 Likes on 4,762 Posts
Did the left secondary timing chain fail???
bob gauff
Old 03-31-2012, 05:15 PM
Stevil's Avatar
Thanks fellas ... It was the chain ... removed and replaced, luckily outside my wallet no serious damage done.
2001 White XJ8
02-25-2021 05:02 PM
pilot435
04-08-2016 06:16 PM
picard
10-12-2015 11:56 AM
ym37tech
09-18-2015 12:25 AM
Kmw
09-08-2015 04:52 PM
Quick Reply: 2001 XJR 100k: P0300 P1316 P1111
