Alan - Sway Bar ........?
Hi to all. Have run into some trouble and would very much appreciate advise...I own a 2002 3.2 litre XJ8. Recently I thought I would fit an anti-sway bar off the 'sports' version to my car. Turns out the bolts from the diff on my car are too short and it means the rear suspension will have to be disassembled to put in the longer bolts onto my dif. When I got the sway bar from the wreckers they only sent the actual sway bar to me , I didn't realise that I would need longer bolts and also different 'washers' for those bolts (and neither did the wreckers). Any ideas ??
I don't think your car has the suspension frame (wishbone tie) piece needed to accept the anti-sway bar. The anti-sway bar does not attach to the bolts for the differential. Only the XJR and the sport suspension XJ8 have the wishbone tie with the flanges to bolt the anti sway bar brackets to. To fit the anti-sway bar to my car I had to make a custom flange and bolt that to the wishbone tie that came with my car.
The drawing shows the wishbone tie from the XJR and sport. The photos show my stock wishbone tie and then with the custom flange and anti-sway bar brackets and bar installed
Very, very many thanks...
To rocklandjag.... Very many thanks for your info about the sway bar , I have been mucking around with this problem for 18 months. As a completely unfair ask, do you have the measurements of the bar you made up ? or could you supply to me another made up bar at whatever cost ?Alanmurg (from Cairns Australia)
Welcome to the forum Alan,
I've added some detail to your thread title.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Sean - I don't know if there would be enough interest to make this commercially viable. I am very pleased with the results. The car corners with less body roll and the front and rear of the car feel like they are at least on the same page when making a turn.
I may have sacrificed some ride quality (it's been installed for too long to remember) but the car is still wonderful on the highway
To rockland jag.... hoping you havent forgotten me. Would still very much appreciate your measurements , notice that there is a 'scolloped piece out of the metal bar and would like to know how deep it is. Also..... if I could get a wishbone tie off a XKR or Sports model of my car , plus the 'washers' , this would solve my problem wouldn't it ?
Thanks in anticipation...Alan
Allen - here are the dimensions of the plate:
- 16" long x 5" tall x 3/8" thick
-the anti-sway brackets are mounted 1" in from each end of the plate
-the bottom hole of the brackets is 1 -5/8" up from the bottom of the plate
-the top hole of the bracket is 2 - 3/4" up from the lower hole
- the cut-out in the bracket for the nut on the pivot bolt is 2"
- the recess in the plate for the differential carrier bolt is 3/16", this allows the 2 nuts to fully engage the threads of the existing bolts
I hope this information is helpful
I recommend that you make a cardboard template of your existing wishbone tie and bolt locations in order to exactly locate the pivot nuts and the 4 differential carrier bolts in case there are any production differences between my car and yours.
If you can get a wishbone tie from an XJR then you won't need to make this plate. I did not think anyone would remove this part from a complete rear end assembly so I made the plate instead
Good luck - you will like the results
Dan R (10-17-2014)
Once again , very many thanks . When I was in the Navy we went to New York for your bicentennial, in 1976. We had a great time in the big apple and the hospitality we received was wonderful, something a person never forgets. Your help just proves the point-nice people.
........From a grateful Ausssie !
Hi, and thanks for your response. The phone number you gave me is obviously in USA. I am in Australia. Could you find out for me if Buckhead Imports have a web sight or an e-mail address , and pass it on to me please ? It would save a lot of hassle for me if I can just buy one "off the shelf" . Many thanks for your interest in my problem...Alan
Received 9,005 Likes
alanmurg (10-18-2014)
