Why should you check/change the tensioners??
Old 05-19-2011, 05:03 PM
motorcarman's Avatar
Received 7,851 Likes on 4,749 Posts
Default Why should you check/change the tensioners??
Some of these parts were preventative maintenance but some were the results of the failed tensioners. Some of the failures resulted in bent valves but others just needed the parts replaced and retimed (LUCKY).
These are just some of the last few years of my 'failed timing components' bin.
I recommend at least checking for cracking plastic tensioners, but...........
bob gauff
Attached Thumbnails Why should you check/change the tensioners??-v8-timing-chains.jpg
Old 05-19-2011, 05:44 PM
TheJagster's Avatar
The whole tensioner issue should be a recall by Jaguar.
Old 05-19-2011, 06:50 PM
plums's Avatar
Received 2,166 Likes on 1,610 Posts
They should have stuck with the system on the V12. Pictures from V12 owners show that they are blessed with a double chain.
Old 05-19-2011, 07:29 PM
Donzi's Avatar
My supercharged VDP has only 45k miles, it is not even getting started again untill
all the tensioners and chains are replaced.
mikiep
12-20-2019 07:37 PM
Jässe in Pälkäne
10-02-2015 05:38 AM
millertic
09-30-2015 08:11 PM
JAMES1944
09-29-2015 11:58 AM
Quick Reply: Why should you check/change the tensioners??
