OK! Where does this one go???
Old 02-19-2011, 08:31 PM
johnny screwdriver's Avatar
Cool OK! Where does this one go???
I'm putting the finishing touches on my 1998 xj8 timing chains and adjusters project!! Got to the cam covers and saw that I needed 3 duplex bolts on each of the top rows to hold the engine covers in place. Problem is; I have 7 duplex bolts!!!!! Where does the seventh duplex bolt go?? THANKS.
Old 02-19-2011, 09:19 PM
ttl's Avatar
ttl
ttl is offline
I can answer, since I just did this myself. Should be left bank, second from front on bottom, for the dipstick tube.
Also, the book says to torque the valve cover bolts in a sequence, basically center two first, then center bottom then center top, then work your way from center to ends, doing each top and bottom pair as you go outward. 9-11 Nm.
johnny screwdriver (02-20-2011)
Old 02-20-2011, 11:56 AM
Thank you, ttl for your quick reply! It IS muchly appreciated.
