Question about programming keyless
Old 04-05-2010, 09:21 AM
Amejin90's Avatar
Default Question about programming keyless
So, I scoured this place for info on reprogramming the key fobs, but like every other noob, it doesn't work. Here is the procedure I followed for my 2001 XJ8 Executive.
Hold the headlamp flasher switch in the on position as you turn the ignition switch to position I
Flash headlamps 4 times to enter alarm programming mode confirmed by the LED on the gear shift flashing.
Program each key-ring transmitter (maximum of five units) by pressing the lock or unlock button on the each key-ring transmitter once. The alarm will chirp a confirmation when you press the key-ring transmitter button.
The alarm must complete a full cycle, (program five times) in order to complete programming
If you are programming only one key-ring transmitter, this needs to be programmed five times
If you are programming two key-ring transmitters operate the first key-ring transmitter once and the second 4 times
For three key-ring transmitters the third should be operated 3 times
For five each should be operated once only
There are a couple of problems with this.
#1, my car is special and doesn't operate like this. I had the trunk open, the door open, followed this procedure and I get nothing.
No beeps, no LEDs flashing, nada. I'd be up for trying some more, but it's after 11pm and my neighbor is certainly considering murdering me by now.
#2, it doesn't say what to do when you are programming 1 key fob for each of 2 physical keys. Do I follow this procedure twice, once for each key, pressing the button on the key fob for one key 5 times then repeating for the other key/fob combination? Or do I follow the whole procedure 5 times, programming the #1 key twice and the #2 thrice? It seems basic, but instructions must be clear since the people following them are obviously dummies like me.
If I can get past #1, I'm sure #2 would make itself clear, but since the car refuses to learn (BAD KITTY!!), I'm stuck at the start. I suppose the LED could be out on the shifter, but that'll have to wait til the weekend and I really would rather not have to open it to check. Any ideas?
Old 04-05-2010, 04:17 PM
newuser's Avatar
I just recently programmed 1 remote and here's how I did it:
1- With driver's door open (not the trunk) I put the key in position # 2
2- Flashed high beam 4 times, then I heard a chirp.
3- I pressed on the unlock button of the remote 5 times
4- got out of the car and tested remote and it was working.
I would assume to program 2 remotes I would press remote #1 3 times and the 2nd remote 2 times. If that doesn't work then I would reverse the order of times I press each remote.
Old 04-05-2010, 09:05 PM
Amejin90's Avatar
Thanks, I try your method tonight if I have a chance and update with results.
Old 04-06-2010, 09:34 AM
Amejin90's Avatar
The method for the XK8/XKR included this little piece of information which proved important:
1. Insert ignition key into the ignition switch barrel, but do not turn it.
I was holding the flasher and THEN inserting the key. If there is a way to do something wrong trust me I'll find it.
Anyway, I was able to get the LED to flash, but there was no chirp. Could this be indicative of some other issue?
Old 04-06-2010, 05:31 PM
newuser's Avatar
Is your car an XK8 or XJ? Because if it's an XJ then you shouldn't have to try the xk8 method you mentioned above . I had to do some trial and error when programing mine till I got it to work. I tried holding the flasher back when I put the key in position 2 and then I tried not holding the flasher. Then I tried just putting the key in but not turning it. I'm pretty sure the one that worked was turning the key but I could be wrong. But I did hear a chirp after flashing 4 times and thats when I pressed the remote button 5 times and it worked. Also try programing 1 remote first instead of both remotes at the same time. If one dosen't work then start the procedure from the biggining with the other remote. Maybe one remote has a bad battery.
Old 04-07-2010, 11:26 AM
Amejin90's Avatar
The car is an XJ8, 2001 just like yours!
Well I can get the LED on the shifter to light up, and it seems to flash once for each time I press the button on the remote, but it doesn't chirp or beep or warble for some reason. The remote still works after that.
What I want to do eventually is to have 2 working remotes since I only got one with the car and it is shared with my wife. It's TOTALLY lame to have to open the door with the key.
Old 04-08-2010, 04:27 PM
newuser's Avatar
So I'm guessing you had success with one remote? If that's the case,again, make sure the battery on the other one is good.
Old 04-10-2010, 12:58 PM
Amejin90's Avatar
I don't know it was successful since thats the remote that was working to start with. The battery in the other one is fine. I swapped it into the working remote and it functioned as normal.
I'm going to double check the part number to make sure I've got the right one.
Old 04-20-2010, 07:06 AM
Amejin90's Avatar
Okay, I was finally able to find 5 minutes to sit down and do this. Now I have 2 operational remotes.
I never did get any beeps, clicks or mewls out of the car, I just had to go by the led flashing on the shifter. I guess it's just not a loquacious kitty.
perfectson
10-06-2015 06:40 PM
bigmikeyt
09-14-2015 12:06 PM
al_roethlisberger
09-07-2015 10:53 PM
Rick Michael
09-06-2015 06:53 PM
My Pham
09-04-2015 03:37 PM
Quick Reply: Question about programming keyless
