Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ ( X308 ) XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X308 ) XJ8 / XJR 1997 - 2003
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Cigarette lighter fuse 1999 XJ8 L
LinkBack Thread Tools Search this Thread
Old 04-05-2009, 11:57 AM
Default Cigarette lighter fuse 1999 XJ8 L
Can anyone help me locate the fuse for the cigarette lighter on a 99 XJ8 L? I looked and can only find a cigar lighter in the book and the fuse is in not in the location in the left side rear heel kick. There is a space for the fuse but one is not there and taking another 20amp and trying to put in in the space does not work. The slot seems to big the fuse fits very loose and just falls out. This can't be the right spot because it was working a few months back.
1999 XJ8 L
2005 XJ8 L
Bill in Maryland
Old 04-06-2009, 03:11 AM
SuperSport's Avatar
Quote:
1999 XJ8 L
2005 XJ8 L
Bill in Maryland
In my manual, it shows it in the trunk in space #5. It also mentions it being a 25 Amp fuse. See the attached images.
Now this may not be correct for yours, and if not, let me know. I should be able to find an answer for you.
PS: The position you mention that feels loose is in fact not a used position. There are quite a few spots that don't have any fuses in them.
Cigarette lighter fuse 1999 XJ8 L-fuse-locations.jpg   Cigarette lighter fuse 1999 XJ8 L-cigar-fuses.jpg
__________________
My SOLD 1999 XJR Replaced with a 2003 Land Rover Discovery II 4.6L
My Jaguar Files Collection
The Following User Says Thank You to SuperSport For This Useful Post:
icecreamchugk (07-06-2012)
Old 04-14-2009, 01:01 AM
Send a message via AIM to blkholsuhn Send a message via Yahoo to blkholsuhn
man, i had the same problem in mine...i have a 98 XJ8-L...i found it to be below the rear passenger seat. theres a little kick panel you pull off and the fuse is in that box(supposing the 99 are the same as the 98). hope you find it
__________________
1998 XJ8
1982 XJ750
2006 Buell
Old 06-27-2009, 01:06 PM
pschlae
Guest
Posts: n/a
Default #5
@supersport. Thanks a lot... It was exactly at the position and blown.
Could you give the number on the back of the manual where you made the scans out of. Because my manual is completetly wrong...
Old 06-29-2009, 12:31 AM
SuperSport's Avatar
Actually, it's out of Jaguar's Downloadable PDF Manual straight from their Website.
http://www.jaguarusa.com/us/en/owner...manuals/xj.htm
The 2000 Manuals are what I use, and I have yet to find a difference from my 1999 XJR. I'd highly recommend downloading these while they are still available and keep a copy on your computer.
To read them, you'll need Adobe Acrobat Reader.
http://www.adobe.com/go/EN_US-H-GET-READER
Glad it helped!
__________________
Last edited by SuperSport; 06-29-2009 at 12:34 AM. Reason: Wrong Manual. Changed to XJ
Old 08-10-2009, 02:08 PM
reyscorpio
Guest
Posts: n/a
Default 1999/2000 XJ8 Downloadable Manual
Hi,
First I'd like to thank you for posting the Cigar Fuse location pages. It will help me resolve that issue.
I went to download the 99 Manual but it is the same one I own and it does not reflect the information you posted. Is it possible for you to post the manual to this site?
Old 08-11-2009, 03:30 AM
SuperSport's Avatar
Quote:
Not a problem. Unfortunately, the files are too big for attachments on this site, so I'll post them on MediaFire. See Link Below. Fuse locations are found in the file "Jaguar_XJ_2000_Vehicle_Care_Handbook" Sections 4-12 thru 4-24. The other two files are ones I like to have on hand.
http://www.mediafire.com/?sharekey=3...e4b9ac475cdcd3
Let me know if there is any problem with any of these.
EDIT: Yes, I noticed that Jaguar changed their site, and these files are a LOT harder to find now. I just keep them on my computer.
__________________
Old 08-12-2009, 02:42 PM
reyscorpio
Guest
Posts: n/a
Thumbs up Thanks
All the files were located and downloaded w/o issue.
Thank you very much. I appreciate your consideration and genorosity.
Old 11-09-2009, 10:29 PM
underwaterguru
Guest
Posts: n/a
Default thanks for the help
Thanks for the help. I went to the manual and did not find any fuse at location 14 under the right side pass seat. One quick log in here and I found it at location 5 in the trunk. Saved me a trip to the shop. Thanks
Old 06-20-2010, 09:26 PM
Talking Driver's Manual Wrong?
I have a 99 XJ8 and the manual supplied with my car says that the cigar lighter is in the right hand heelboard, position 14. There is nothing there. I searched this site and found this post. After reading it, I checked out fuse #5 in the luggage compartment. Sure enough, it was blown. I replaced it and all works. My manual says the fuse I just replaced is the left and right seat timers. I downloaded the 2000 manual that was referenced. I find it odd that the manual that came with my car has the wrong fuse diagram. Thank you so much for posting this information, I never would have found it on my own.
The Following User Says Thank You to IcyBlueRose For This Useful Post:
Blue_XJ8 (02-17-2014)
Old 06-21-2010, 12:17 AM
QuadManiac's Avatar
FYI here's where you can download the comprehensive electrical diagrams for your Jag - virtually any year/model:
http://www.captainjaguarscathouse.co..._Reference.htm
__________________
2000 XJ8 Anthracite/Charcoal
Old 06-30-2010, 01:58 AM
Send a message via AIM to chaseatl Send a message via Yahoo to chaseatl
Default XJ8 L fuse
The fuse in the XJ8L is located right rear passanger heal board fuse panel. You have to unscrew the carpet cover to access it.
Old 07-02-2010, 10:32 AM
Send a message via Skype™ to joolz
Hey SuperSport,
Thanks for the link to the manual!
Joollz
__________________
Why yes! It IS a purple Jaguar... but I prefer to call it amethyst! How else could I carry my golf clubs?
Old 07-03-2010, 06:14 PM
Smile Thanks!
Thank you so much for the link to the manual. I now have it saved to my computer.
Yes, there is a fuse box under the heelboard -- I found that, and slot 14 was not in use. I had to use the manual for the 2000 XJ8 for the correct diagrams. Why the manual for my 99 XJ8 is wrong, I don't know. All I know is that without this thread, I never would have figured it out on my own!
Old 08-02-2011, 02:48 PM
I have checked all my 25 amp fuses and I still cant get the lighter socket to work. I have a funny feeling the complete cylinder may be bad, Cause there is some rust inside of it.
Does anyone know if there is an easy way to access the cylinder to take it out?
I have tried to twist it from the inside but Im worried it might snap.
Old 08-02-2011, 07:53 PM
Vector's Avatar
Untitled
Neither the front nor rear lighter sockets worked on my new Jag. I really didn't care until I went to plug in my radar detector tonight. I found a blown 25 amp fuse in position 5 in the fuse box in the trunk, next to the battery. Replaced it and both lighters work now, thanks!
(BTW, it was kind of creepy that I read this post right before my Wife and I went out for an evening drive in the XJR. I did not know that the lighter sockets did not work. She was amazed when I opened the trunk, found the only 25 amp fuse in the box, replaced it and the radar detector works now! You guys make me look good! )
__________________
"I have come to understand that owning a Jag is like owning a horse. There's no joy in it unless you love taking care of it."
01 XJR, Anthracite Pearl Metallic/Ivory
Secondary Tensioners done.
RealGauge. Antenna switch installed. Trans fluid changed. Supercharger oil changed.
Red Calipers. Electric exhaust cut outs installed, WOW! Fender leapers changed to side markers.
Old 09-28-2011, 04:25 AM
Jalo
Guest
Posts: n/a
Thanks for all the great info. You have been a life saver. Cheers Jalo
Old 09-28-2011, 07:20 AM
Hi
Make sure you remove the battery ground cable (negetive post). You need to remove the center console, then pull out the cigarette lighter from it's cigarette lighter housing (if it is not already removed).
Now you can remove the cigarette lighter housing (the cylinder is you are referring is the housing).
To remove cigar lighter housing:
Remove tape securing harness to console underside.
Slacken and remove retaining ring from underside (of cigar lighter housing) and remove housing complete with cable.
Jim Lombardi
Old 05-21-2012, 11:00 PM
ralfvandersluis's Avatar
The word "hero" is so often overstated. But not here. The people who pointed me towards fuse #5 are just that. Heroes. One radar detector, one cell phone charger, one bluetooth charter, one sat nav charger back in business !!!!
Praise be!! Praise be indeed!!!
__________________
1999 XJR, 1997 XJR (gone but not forgotten)
Old 09-22-2013, 12:35 PM
Guys, you all are wrong in the location of the cigar lighter fuse in a '99 XK8. It is in the passenger side (USA) fuse box inside the dash. #14 20 amp slot. Open the door and there is a fuse cover. Remove it and that is the location.
Cheers,
Craig
Tags
1999, 2006, 25, 98, amp, cigar, cigarette, fuse, jaguar, lighter, location, type, working, xj, xj8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
