Cigarette lighter fuse 1999 XJ8 L
Old 09-22-2013, 11:54 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
bowmanec-
That was a very insiteful post EXCEPT this is the XJ308 forum and there are no fuses in the dash!
Old 01-18-2014, 02:58 PM
jedihomer's Avatar
Just to add to this; My UK '98 XJR cigarette lighter fuse was fuse 14 found under the back seat behind the driver's seat..
Old 02-17-2014, 09:21 PM
Blue_XJ8's Avatar
Glad I found this post. My cigar lighter used to work, but eventually stopped working. I was looking for the fuse and as many mentioned here I went "by the book" to #14 right hand side rear heal box. Not fuse position !! Was scratching my head. Will look in trunk, even though I tested all my fuses and only one I found blew up was back seat warmers related. Might have to consider replacing it (or remove and clean it) as appears quite corroded.
Old 06-18-2015, 01:49 PM
axel1961's Avatar
Thumbs up cigar lighter not working 'FIX'
Hi, thanks to you all for this fix my xj8 x306 2001 cigar lighter fix in the boot position number 5 broken 25 amp fuse changed and both lighters working yeaaa cheers
Old 11-01-2015, 10:50 AM
epereira's Avatar
Guys thanx you very much. Saved me a lot of work searching for the lighter fuse in spot 14 on the right heel panel. Yes it is in the trunk in spot 5 on the 99 XJR.
Eon
Old 11-02-2015, 01:40 PM
sparkenzap's Avatar
Originally Posted by bowmanec
Guys, you all are wrong in the location of the cigar lighter fuse in a '99 XK8. It is in the passenger side (USA) fuse box inside the dash. #14 20 amp slot. Open the door and there is a fuse cover. Remove it and that is the location.
Cheers,
Craig
Of course, this is the XJ8 forum, and the fuse location changed as posted by the masses!
hamilton7550
07-30-2021 11:29 PM
dude1579
08-12-2019 06:29 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
mhenz
09-14-2015 07:47 PM
jagent
09-12-2015 01:40 AM
Quick Reply: Cigarette lighter fuse 1999 XJ8 L
