clock light bulb for 1998 XJR
Old 12-31-2010, 09:43 PM
HARV's Avatar
Question clock light bulb for 1998 XJR
Hello,I need the little light bulb for the clock in my XJR,do I need to get this from a dealer?Thanks for the help
Old 01-01-2011, 04:10 AM
Cadillac's Avatar
As this place is mainly made for new members introductions I moved off your thread into the proper area
Old 01-01-2011, 11:06 AM
DavidN's Avatar
You'll need a OEM bulb, as this special bulb is of a blueish/greenish color.
To exchange the bulb you have to remove the center vent.
- Pull off the center veneer
- Pull off the veneer cover of the instrumant cluster
- Pull off the veneer covering the passenger airbag
- remove a few philips head screws and pull off the center vent
- Now you have access to the clock
(Part # of the bulb is imprinted on the back of the clock)
HTH
David
HARV (01-01-2011)
Old 01-01-2011, 12:19 PM
HARV's Avatar
Thanks David, I got the clock out and found the part # for the bulb.
99xk8guy
06-05-2023 06:28 AM
Rlover
03-30-2016 10:04 PM
afterburner1
12-16-2015 12:12 AM
SteveSheldon
UK & Eire
09-08-2015 11:22 AM
gene1
09-03-2015 05:58 PM
Quick Reply: clock light bulb for 1998 XJR
