Coolant reservoir leaking...
Old 05-08-2013, 06:43 AM
princemarko's Avatar
Default Coolant reservoir leaking...
Does it need to be fully swapped out? or is it repairable? Could it be that sensor?
Old 05-08-2013, 08:44 AM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
The sensor is not a source of leaks. While some have patched it, I think you will find the plastic cooling system parts have become brittle with age and heating cycles. Considering the risk of severe damage due to overheating these engines it would be my choice to replace it.
Old 05-08-2013, 10:29 AM
dsnyder586's Avatar
Replace. Last thing you want is an 85 mph reservoir burst and overheat.
On a side note, I purchased a coolant pressure tester this week for my fleet (family of 6 drivers) and it has already paid for itself with the first use. (didn't have to hunt and peck for the leak it showed up as soon as I added pressure) If you do not have one, spend a few bucks on it- well worth the $.
Tirefriar (05-08-2013)
Old 05-17-2013, 05:49 PM
Sensor was the source of the leak... Replaced the whole tank
Old 05-17-2013, 07:40 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Well, the well that the sensor clips into may have been leaking, but the sensor itself is external to the tank
Old 05-18-2013, 02:29 AM
QuadManiac's Avatar
Yep - BTW, Gus has a good write-up on the sensor on his website.
MrWhite
19
06-14-2022 07:49 PM
Poet
06-07-2019 07:54 PM
X308XJR
05-20-2019 06:50 PM
Gregory Neil O'Rear
09-29-2015 09:52 AM
Quick Reply: Coolant reservoir leaking...
