Expansion tanks.....
I would like someone to educate me on the purpose of the second expansion tank under the LH headlamps. My car has had a chronic leak there so I removed it and found the spigot on the side was just an open hole. I don't see any hose nearby to connect to it.
Is it there solely to collect overflow from the upper reservoir? Was the tank (MNC4460AD) originally plugged at that spigot?
Many thanks.....
Many thanks.....
It is suppose to be open to the atmosphere. Will leak if cracked: but if it is overflowing, most often due to wrongly connected overflow pipes from topside reservoir. The hoses need to cross over -- techs not familiar with this engine will often misroute these after radiator or water pump repair
The header tank is a non-pressurized "overflow" tank that enables hot coolant to be stored temporarily. When the main engine coolant is heated it expands, and if the level in the expansion tank is at the correct level this "excess" volume will overflow into the header tank, controlled by the expansion tank cap. (The header tank is designed to vent to atmosphere if the tank gets too full). When the engine coolant cools, the "excess" coolant in the header tank is sucked back via natural vacuum into the expansion tank to maintain a proper level. It is important that you do not remove the header tank.
motorcarman (10-20-2021)
Many thanks.....
Many thanks.....
Open
02-03-2020 06:25 PM
Plant
06-18-2013 01:08 AM
cliff328
08-19-2012 10:02 AM
