Exhaust shield placement
Old 08-11-2012, 03:05 PM
dsnyder586's Avatar
Default Exhaust shield placement
Does anyone have a blowup of where the heat shields go on an XJ8 at the manifold/cat junction? I didn't take note...
Old 08-12-2012, 05:54 PM
Well, this is sort of cryptic, but hopefully it will clear it up. Match the stud numbers with the hole numbers on the illustration. Install on the studs in the 1st, 2nd, 3rd order marked. All three studs will have a spacer on them, two are welded to the triangular bracket, the third may or may not be attached to the 1st shield. If it's not, just be sure it gets on stud three before you install the shield.
Good luck!
File Type: pdf
The following 4 users liked this post by xjrguy:
dsnyder586 (08-13-2012), jimlombardi (08-12-2012), Watersidejag (10-17-2020), Will P (10-29-2015)
Old 08-12-2012, 07:43 PM
jimlombardi's Avatar
Received 1,618 Likes on 874 Posts
Hi Steve
Nice response and informative diagram.
Jim Lombardi
xjrguy (08-12-2012)
Old 08-13-2012, 12:36 AM
dsnyder586's Avatar
Definitely- Exactly what I was looking for!
Old 10-06-2012, 03:50 AM
Guitarman944's Avatar
Similar problem here too do the alum shields go under the water filler side? And the fibre glass monstrosity on the other my XKr is right hand drive
Guitarman944
Joachim1167
11-07-2020 09:18 PM
Poet
06-07-2019 07:54 PM
boiler
US Southwest
10-17-2015 09:35 PM
baskervillema
10-01-2015 06:43 PM
Quick Reply: Exhaust shield placement
