Heated seats
The seat heaters are controlled by the BCM through the seat module plus there is a thermal switch in the heating element itself. The heating element is in both the seat and the lower back area. The thermal switch is set for a pretty low level and never really gets noticeably warm . . . at least in my car. The seat module and the thermal switch are the first failure choices.
There is a thread describing how to replace/modify the thermal switch that can be found with a quick search.
The owner's manual makes it sound like they get to a certain point then stop heating up more.
I will have to read more about this because like my seats to be really warm.
There is a pictorial of replacing the thermal switch buried in the seat bottom somewhere. You can bypass it or move it further away from the heater element for higher temps. Sorry, couldn't find it at the moment.
FOUND IT!
https://www.jaguarforums.com/forum/x...-solved-44965/
FOUND IT!
FOUND IT!
FOUND IT!
I did not read about moving the thermal switch away from the element tho. Are there suggestions here?
I did read some talk of people finding a rheostat but no one ever did. It's too bad Jag did not put a mulit level, or even a rotary, switch like some do.
BTW, my brother had a 81 Volvo Bertone. Cool but crazy looking. Those chopped down windows were something. I think they are only offered in the states in the two tone brown and gold combo in 91. Best color of the three years.
42Ajd
12-30-2015 09:45 AM
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
Poet
10-06-2015 09:40 PM
adam699
09-12-2015 05:32 PM
jagent
09-12-2015 09:10 AM
