How do I unlock the gas cap on my '02 VDP?!
Old 02-07-2011, 01:38 AM
vdpnyc's Avatar
Question How do I unlock the gas cap on my '02 VDP?!
So far the only way that I have figured out is to put the key in the drivers door and and turn clockwise (that is ridiculous, I know, but it seems the gas cap is always locked otherwise)
Old 02-07-2011, 01:59 AM
QuadManiac's Avatar
When the doors are unlocked, the gas cap cover is unlocked also. When doors are locked, cap cover is locked.
Old 02-07-2011, 02:08 AM
vdpnyc's Avatar
Definitely not the case for me, I don't remember if my last gas-up I pressed the dashboard unlock button or if I opened the driver's door to unlocks all doors, but one of those definitely did not open the gas cap (need more experimenting to confirm which)
Old 02-07-2011, 10:53 AM
Sinister 1's Avatar
I got tired of playing games with mine and disabled the lock feature on the fuel door by removing the plastic lock tab on the bottom of the door.
It's a useless feature anyhow. If you saw the contraption down in the tank that prevents fuel spill out of the filler in the event of a rollover, you'd agree that siphoning fuel is unlikely. Not impossible but very unlikely.
I guess I may have to worry about someone adding sugar to the tank, but I try not to have to many enemies anyhow.
Ken
Old 02-07-2011, 02:13 PM
vdpnyc's Avatar
LOL, Ken does that mean that you also had unlocking issues?
Old 02-07-2011, 02:48 PM
JimmyL's Avatar
Valet mode. Gas flap and boot switches won't work.
Old 02-07-2011, 03:14 PM
Stu 1986's Avatar
Or a blown fuse as it was in my case!!
Old 02-07-2011, 07:30 PM
Sinister 1's Avatar
Yep. One time at the pump it would not open. Problem was solved with a screwdriver. You'll be shocked at how little security the locking lid offers. Heck I think I could have popped it with my bare hands if I wanted to bad enough.
Old 02-08-2011, 01:24 PM
Stu 1986's Avatar
You can also manually unlock it from inside the Boot/Trunk by pulling back the carpet at the side and sliding the lock mechanism. That is what the Owners Manual says. S.
Old 03-05-2017, 10:41 AM
catgordon's Avatar
I wish that worked for me but it didn't. I tried opening the cover in the left rear trunk and saw the switch but could not manually move the locking mechanism. also when I put the key into the drivers lock, turned it clockwise, all four windows went down. I had changed the fob battery but no change and neither fob appears to lock or unlock the doors.
Old 03-05-2017, 11:16 AM
Daim's Avatar
Received 2,180 Likes on 1,583 Posts
You held it too long in the turned position.
Old 03-05-2017, 12:24 PM
Received 7,878 Likes on 4,762 Posts
nilanium (03-05-2017)
Old 03-05-2017, 05:21 PM
omgimali's Avatar
Old 03-05-2017, 06:52 PM
Rpach10115's Avatar
The steering wheel is on the wrong side.
Old 03-05-2017, 07:47 PM
omgimali's Avatar
Erm it was a recall......
aholbro1
08-05-2021 05:02 AM
Russ Graber
02-23-2019 11:59 AM
duecedriver
12-25-2015 11:47 AM
Papelione
09-21-2015 06:13 PM
pab
09-16-2015 10:34 AM
Quick Reply: How do I unlock the gas cap on my '02 VDP?!
