How do you remove wiring harness clips from valve cover?
Old 03-01-2015, 02:17 PM
schoeman's Avatar
Default How do you remove wiring harness clips from valve cover?
Sorry for such a noob question, but I want to replace the valve cover gaskets on my 2001 XJ8 and the wiring harness is clipped into the valve cover with little plastic cones that snap into a small round metal hole. Is the only way to remove it is to cut off the heads? If so, how does one refasten the harness afterwards? THANKS!
Old 03-01-2015, 05:16 PM
GGG is offline
Received 16,759 Likes on 12,148 Posts
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old 03-01-2015, 05:21 PM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
Pick up these trim tools at a Harbor Freight near you: 5 Piece Auto Trim and Molding Tool Set
The old brittle plastic still might break in some instances, but these give you the best chance of removing them intact. If they do break, zip ties can be used as a substitute.
Old 03-01-2015, 08:10 PM
luc's Avatar
luc
luc is offline
push them up from the back of the holes with something like a small bolt
schoeman (03-01-2015)
Old 03-01-2015, 08:13 PM
schoeman's Avatar
Okay. So I guess the idea is to force them, and if they break they break. Thanks!
Forcedair1
05-14-2023 03:28 PM
dsnyder586
04-04-2019 02:38 PM
Dicque
09-19-2015 12:53 PM
philwarner
09-06-2015 11:10 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: How do you remove wiring harness clips from valve cover?
