Intermittant fault at start up
I have a 2001 XJ 4.0 V8. I has an intermittent start up issue, which is strange and annoying
The dash board information panel reads in sequence
1. Trax on available
2. ASC not available
3. Gearbox failure
4. Engine in failsafe mode
The ignition key cannot turn and the gear lever is locked into park and the car will not start! It eventually will start, perhaps over an hour later.
I have had the ABS booster pump replaced, have had all of the ABS sensors tested, their earths and wiring checked, the gear lever micro switch is perfect and I have replaced the battery. Nothing is showing up on the diagnostics. My local Jaguar dealer is as baffled as I am.
What can it be?
3. Gearbox failure
What can it be?
Welcome to the forum GaineR,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
GaineR (09-16-2014)
I had a problem with the main ground strap at the battery. Called the wife to come and give me a jump, and when I just fiddled with the ground strap the car started. It was also very hot. Turns out the connection at the crimp was not good (although the ends were fine). I think I added solder at first, but eventually replaced it.
To AVT007: Thanks I've installed a new inertia switch, new engine earth strap and a new battery earth strap. So far so good' Very good electrical fault guide that you produced! Thanks!
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
