Rear view mirror won't dim.
Old 03-02-2020, 01:24 AM
Ed Rice's Avatar
Default Rear view mirror won't dim.
Can I fix it or do I have to replace? If replace where can I find a replacement?
Old 03-02-2020, 01:39 PM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
See if this source is still active:
Mirror Repair
Old 03-02-2020, 02:00 PM
Received 7,878 Likes on 4,762 Posts
SYBESMA'S has been repairing all mine for years.
Old 03-02-2020, 11:39 PM
Jeroen's Avatar
I had mine repaired by Sybesma some 10-11 years ago. Still working properly!
Electronics Services Sybesma's Electronics
Jeroen
Old 03-03-2020, 12:21 AM
King Charles's Avatar
Received 1,019 Likes on 740 Posts
Another vote for Sybesma.
Old 03-03-2020, 12:42 AM
ericjansen's Avatar
Received 1,351 Likes on 926 Posts
Here is an alternative to Sybesma, cheaper I think.
Member #HIGHHORSE here had some very good experiences with them, my mirror is ready to be shipped (as soon as this virus craze lowers down).
https://www.radar-mirror.com/mirror_repair/
Old 08-07-2020, 01:33 PM
Carguyjohn52's Avatar
I need to send my 97 VDP mirror off for repair, but have read the stories on here about breaking the windshield, so going slow! It appears the wire ‘cover’ at the top needs to come off to begin. One drawing indicated it pulls off straight toward the back of the car, but something has to hold it on! Does anyone have a photo of the cap off the stem, or has removed this style that can advise?
thanks
Appears upper cap should be removed first? Mirror then slides ‘down’ off windshield post?
Old 08-07-2020, 05:14 PM
This is the XJ8 forum but the mirrors are similar.
I use pocket screwdrivers to pull the mirror DOWN and off the mount base if the is the type you have.
There is a triangle type mount for the X300 as well. (To VIN (746813))
The rectangle mount is the same as the X308 style. (From VIN (746814))
Old 08-07-2020, 06:25 PM
Iconoclast's Avatar
Do some searches for:
XJ mirror replacement.
Magna Donnelly
Sybesma
There are several threads on; mirror factory defect, replacing it, breaking windshield, loose mirror, etc.
In 2007 they were replacing the defective mirror @ N/C. Some people had liquid leak from mirror & damaged their car finish where the liquid dripped. Others just had spots on the mirror. It was filled with a liquid & the replacement mirror was filled with a gel instead.
I replaced my mirror which had 'spots' @ N/C in 2007.
5 years later same exact issue!
Now I had to go through Sybesma & pay $95 + shipping. And be w/o the mirror for 1.5 WEEKS. (At the time this was my only car.)
The original replacement was likely new, old stock that still had the factory defect liquid inside.
So far the 2nd replacement is holding up. Sybesma confirmed the 2nd replacement has gel inside.
When you find these threads, there are photos & how to descriptions of how to remove the mirror with little chance of damage to windshield. Also info on loose mirror.
Don't just go for it w/o reading about tips to do it safely & letting some mechanic rip it off may get you a broken mirror mount & cracked windshield.
Plenty of information here in MF re this issue.
Old 08-10-2020, 04:03 PM
Thanks very much- a photo tells so much! I had it off the car and packed in 10 minutes. Much appreciated
Old 08-10-2020, 09:01 PM
Iconoclast's Avatar
If you searched & read the other threads you would know that pulling straight back towards the rear of the car is exactly how some cracked their windshields!
You must remove & reinstall by moving the mirror & mounting assembly parallel to the windshield.
Old 08-10-2020, 09:18 PM
I install them in the same fashion but pull UP with the screwdrivers as leverage.
Old 08-11-2020, 02:02 PM
Col. Sandurz's Avatar
missed this one, I have a perfectly workiong one in basement.
Old 01-11-2021, 05:29 PM
KipnKnox's Avatar
I contacted Sybesma’s last week. They still do repair them. It’s $175 now and that includes shipping and handling. 3-5 day repair time once they receive it.
Old 01-11-2021, 06:07 PM
For $100 I’ll send you my working mirror
qwakwak
08-07-2020 06:18 PM
Rigsby94
05-31-2012 10:27 PM
ant17
05-25-2011 11:09 AM
Quick Reply: Rear view mirror won't dim.
