Only starts in 'N'
Old 05-21-2011, 06:03 PM
teflontony's Avatar
Default Only starts in 'N'
My XJ8 will only start in N, in P it just spins over without even a cough.
Once started everything seems ok, although it sometimes does not want to change up.Moving into N, then back into drive usually cures that.
Old 05-22-2011, 04:51 PM
jnunez's Avatar
Hey tefl...sounds like a bad range sensor (Neutral safety switch), or an adjustment for the linkage for the park position...I would start with the neautral switch first...check range sensor hope this helps....
Joe
Old 05-24-2011, 10:34 AM
teflontony's Avatar
Hi Joe.
Will get my friendly grease monkey to check the selector then,
I feel that this is more likely, given that the beast starts in N, so the 'car' knows it's in neutral.
The problem of SOMETIMES not wanting to change up also suggests it may not have selected 'D' properly, as all I do is move from D to N and back and the car will change up.
I just wondered if it were a common fault, if so someone may have just said "Hey Ho, I know what that is", but unfortunately not...
I doubt the company in the link would ship it to the UK anyway, dread to think of the cost.
Thanks anyway.
Terry
JarodL
03-07-2024 01:39 AM
Dagny
07-20-2020 05:39 AM
99xk8guy
09-21-2019 07:34 PM
Bones
09-08-2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
09-06-2015 10:54 AM
Quick Reply: Only starts in 'N'
