Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ ( X308 ) XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X308 ) XJ8 / XJR 1997 - 2003
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Mobil-1 ATF the same as the ESSO ATF?
LinkBack Thread Tools Search this Thread
Old 01-14-2011, 10:37 AM
scarbro2011's Avatar
Default Mobil-1 ATF the same as the ESSO ATF?
01/14/11
Is the Mobil-1 ATF an acceptable substitute for the ESSO LT 71141 mentioned
in the ZF-5HP24 manual?
__________________
Jingle-Jags
Bob and Lee Scarborough
1994 XJS - 1999 XJ8-VDP
Old 01-14-2011, 11:08 AM
Yes. The Mobil fluid meets the specs of the Esso fluid.
Some may differ.
Old 01-14-2011, 11:50 AM
Mobil bought Esso. The Mobil 1 is now the Esso LT71141. So much for magic ATF.
__________________
North Georgia SPRING 2015 Trout and Cars http://www.jaguarforums.com/forum/us...1/#post1184744
2002 XK8
2001 Honda GL1800A
1982 Volvo 245 Ford 302 V8 http://forums.turbobricks.com/showthread.php?t=250257
1981 Volvo Bertone Coupe - 25k original miles http://forums.turbobricks.com/showthread.php?t=256460
Old 01-14-2011, 12:17 PM
Another nice piece of data for my XJ8 folder for vital JAG bodily fluids.
Thank you both for the info.
__________________
Jingle-Jags
Old 01-14-2011, 02:04 PM
test point-
heh, heh.
__________________
Ross
MY 89 V12 convertible
MY 99 XJR
MY 02 XJ8
MY 12 XF R
Old 01-14-2011, 03:17 PM
Originally Esso LT71141 was a semi-synthetic oil and you could not buy it in quarts. They sold it in L bottles in europe.
Esso is "S" "O" for Standard Oil -- The Rockefeller standard oil. In the early 70's the name changed to Exxon for marketing reasons in the US and a few other places.
Then Exxon and Mobil merged.
So Mobil 1 is not the same as the original Esso LT 71141. Mobil 1 is fully synthetic. But Mobil 1 meets the spec of LT 71141. You can still buy Esso LT1141 (although it is now labeled as Mobil LT 71141 and sold by the L)
If you go to the Mobil site it will tell you Mobil 1 meets the spec but they will not tell you it is guaranteed for a ZF box.
I believe the ZF oil is still semi-synthetic -- they claim additives and actually sell two different versions depending on the box.
But since ZF says you can use an oil that meets the spec of LT 71141 you can use Mobil 1 ATF.
It may just be like the fluids for the Mercedes boxes. You have continual innovation in fluids, they discontinue the old fluids but the new fluids are backwards compatible but the reverse is not true. Some believe that the older MB boxes (XJR's) work better with the original fluid as supplied.
But Mercedes does not charge as huge a premium for the fluid as ZF does.
Old 01-14-2011, 03:52 PM
A number of other suppliers claim to meet the LT71141 spec also for around $5 a quart.
Guaranteed? Guaranteed for life?
__________________
2002 XK8
2001 Honda GL1800A
Old 01-14-2011, 04:33 PM
"Guarantee" is the word I used to express the situation -- that Mobil makes no claim for Mobil 1 other than the spec. Some companies do list applications.
15 years ago, cars did not last as long as they do today. The idea of transmissions regularly going past 120k and engines past 150k was not a reality. The part synthetic fluid of this period had a service life that exceeded the estimated life of the component.
Old 01-14-2011, 05:03 PM
Does anyone else see the absurdity of the phrase "guaranteed for life"? It's not your life, but the gearbox's, and when it blows up, IT"S LIFE IS OVER!
__________________
Ross
MY 99 XJR
MY 02 XJ8
MY 12 XF R
Old 01-14-2011, 08:28 PM
Most of the early failures in the ZF boxes were due to metal fatigue in the A drum. No lubricant could have stopped this.
Old 01-14-2011, 10:10 PM
Dan has mentioned the weakest part of the ZF box. Mercedes had a bearing problem in the earlier units that they fixed around Y2K - also nothing to do with the fluid.
But, often the fluid was blamed. I believe fluid is to blame for some of the failures -- but its normally from using the wrong fluid or not filling the box correctly.
Old 02-20-2011, 04:58 AM
plums's Avatar
If you look at the Mobil spec sheets carefully, you will see that Mobil calls out another transmission lubricant as the equivalent to LT71141. It is a synthetic blend with a similar name. Down near the bottom of the list.
For the full synthetic, it does not call out LT71141, but the interesting bit is the list of ZF type approvals. If you cross the type approvals with the ZF requirements you will probably find that it is an implied equivalent or upgrade.
On that basis, you could use either one depending on preference for full or semi synthetic.
Old 02-20-2011, 07:52 AM
I don't know how often ExxonMobil releases data sheets -- or how they differ from country to country -- lots of them around. So some confusion is created.
But EM does have M1 ATF as meeting the specification of LT71141 - you can even find discussions of it from Mobil. What they will not say is that M1 ATF can be used in a ZF transmission - only that it meets the specification of LT71141. I used the word "guarantee" in my post to illustrate that Mobil will not make any guarantee regarding the use of the fluid for a given application. This is different than "sealed" or "lifetime" fluid -- under normal conditions. I don't ever remember seeing the word "guarantee" in any literature from ZF or Jaguar
The semi synthetic formula is most likely the original formula -- it has changed names over the years.
I no longer own a car with the ZF box - if I did I would look for the original semi synthetic fluid.
I'm not sure what Jaguar is doing with the Mercedes box in the XJR -- MB no longer sells the original fluid as they have come out with a newer fluid that is backward compatible with the original 5 speed fluid. The old fluid is still widely available on the shelf in some areas -- but I have no idea if it is still being manufactured. Jaguar may have a lot of it. Same box is used in many Porsches - I have never priced it at the Jaguar dealer.
Old 02-20-2011, 08:59 AM
Stu 1986's Avatar
I used the Mobil stuff in my car when I had the fluid changed. I have 12 litres of it left and have advertised it for sale on the forum. I am in the UK and if anyone is interested PM me. S.
__________________
1999 Jaguar XJ8 4.0 Special
1971 Triumph Herald 13/60 Convertible 2.0 Vitesse Straight 6
The Art of Performance
"Don't trust anything that doesn't have an engine"
If you still get excited each time you get in your car, you have the right car.
Old 01-16-2014, 12:15 PM
Well, I still don't get it. Yes, or No?
I went to the Mobile website, looked up the question - and here's how Mobile dealt with it...
Question:
Does Mobil 1 Synthetic ATF Meet the Requirements for ZF Transmissions?
I have found out that Mobil is recommending the Mobil 1 Synthetic ATF as a replacement for the Esso LT 71141 ATF used in BMW transmissions. I have a 1998 BMW 750iL with a ZF 5HP30 transmission, does Mobil Oil guarantee this product as meeting all the requirements of the ZF transmission?
-- McGarvey Cline II, Gainesville, FL
Answer:
No. We do not guarantee that the product meets all the requirements of ZF transmissions, which are very extensive depending on the transmission type/model year. ExxonMobil does say that this product is suitable for use in this application based on the type and quality of the recommended fluid, Esso LT 71141.
Quoted from this LINK
__________________
Dan Smith
1999 XJ8 VDP
Tags
04, 71141, atf, buy, esso, jaguar, lt, lt71141, mobil, semi, specification, specs, synthetic, vs, x5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
