New to me XJ8 Trans issue
Hello all,
I just bought my first Jaguar, a 98 XJ8 with a transmission issue. After much reading it appeared to be the forward drum. I ordered the new improved drum and the needed o rings, trans oil, and filter kit. The removal was a bit involved but not so bad. The exhaust was by far the hardest part. I did end up with a damaged threads in the trans cooler port but was able to get it so the line did tighten and no leaks so far.
I used Amile universal synthetic oil to refill it and seems just fine. I should have done a video of the job but just wanted to get it done so I could drive it! I was surprised how easy things went. The only transmission I had repaired before this was a Subaru years ago.
My new car runs and shifts just right now. One happy camper!
Here is the pdf by ZF and the valve.
http://www.jagrepair.com/images/Auto...%20ZF5HP24.pdf
Main Pressure Valve 5HP24 - 5HP30
The CAUSE of the drum failure is not a defective drum but pressure spikes caused by the pressure valve. The new drum is simply overkill but does nothing to cure the cause. And yes, there are many, many transmissions repaired without any maintenance on the pressure valve, personally after changing my own transmission I installed a rebuilt valve assembly for a forever repair, I may live in Nevada but I do not gamble!
Wes Steenrod
09-06-2015 06:52 PM
