nikasil and injector cleaner?
Old 02-25-2013, 07:22 PM
andrew lowe's Avatar
Question nikasil and injector cleaner?
i have a 1998 xjr with its original engine [105,000 miles] i have done the chains and tensioners, but what i would like to know is it ok to use an injector cleaner, either diy [pour a bottle of x in the tank] or one of the pro flushes ? would any of them harm the nikasil? or should i just let the old girl soldier on as is?
Old 02-25-2013, 10:07 PM
coastaljag98's Avatar
If its running fine leave it alone. Mine has 194k runs fine.
andrew lowe (02-26-2013)
Old 02-25-2013, 10:32 PM
Gus's Avatar
Gus
Gus is offline
Received 2,206 Likes on 1,700 Posts
Why do you want to clean the injectors? The only enemy to Nikasil is Sulfur. I use BG44K once a year.
Old 02-26-2013, 09:42 AM
danielsand's Avatar
My VDP is 98 with 85K on original engine. I use Lucas on every third-fourth tank.
Old 02-26-2013, 10:07 AM
jimgoose's Avatar
+1. Possibly the greatest injector cleaner known to science.
Old 02-26-2013, 10:13 AM
Sean B's Avatar
Received 1,333 Likes on 1,053 Posts
Default Bg44k
It's the only one Jaguar recommend.
Old 02-26-2013, 11:56 AM
danielsand's Avatar
I've never seen this one in my local stores.
Old 02-26-2013, 12:23 PM
Gus's Avatar
Gus
Gus is offline
You will not find in most local stores but you will find it in most dealerships or garages. It is good stuff and at $20.00 +/- a few it should be.
JCam
10-23-2016 08:27 PM
jospolice
10-02-2015 07:16 PM
reb1999
09-26-2015 08:41 AM
SD96XJ6L
09-25-2015 10:53 PM
Quick Reply: nikasil and injector cleaner?
