Opinions on what is the best oil filter available today?
Received 10,749 Likes
Wix/Napa, AC Delco, Purolator, OEM Jaguar......I'm sure any of them will be good. I would 'recommend' them.
Which is 'best' is another question entirely, and one I can't answer
I'm normally pretty nonchalant on the subject but one lesser known brand that has caught my eye is Baldwin. Those who use them are usually very intensely convinced that they're 'the best'. Probably worth researching.
I'm sure others will chime in.
Received 2,255 Likes
JimC64 (02-14-2014)
I think in this day and age most of the filters available on todays market
are perfectly fine, as long as they are equiped with the anti-drain back valve and pressure by-pass valve.
There have been some over the top threads regards the interior and filter medium used in some filters but honestly, in todays modern engines which run so much cleaner and the ability of modern oils to hold muck in suspension for longer, if you change your filter regularly, you have no problems.
I remember a discussion on one of the Harley Davidson forums where they beat the bejeeesus out of the discussion and it still came down to most modern filters all pass the tests and do their respective jobs.
Take away the marketing hype and go with what you are comfortable with ;o))
I personally use a range of filters from the OEM to Ford, Ryco, Fram and others.
Whatever I can get a good price on a six pack at the time ;o))
Amazon is your friend.
While there might not be a "best" filter, there are some that are really, really bad.
The BOSCH 72209 listed by Bosch for X308 is an example of bad. Not really bad. Just that it is made shorter than spec to fit both the earlier and later mounting systems. Not so easy to figure out in advance when buying online.
The Fram and Purolator, well they've been cut open and examined. Even the premium models are not so premium.
So, it becomes a question of which filters (plural) are good and of course which very few are excellent. Using the word "best" in the question is where it becomes a heated argument. This ain't twatter or spacebook.
Another very well made filter is by HI-FI....these are made in China
and are the equal if not better than the OEM filters.
Hi-Fi No.HV-5317
I totally agree about the Bosch filters....utter crap and
I'm quite surprised at this with such a well known name.
I thought I had the discipline to leave well enough alone but obviously I'm a poor judge of my own character .
Define 'problems'.
Do you mean the filter didn't leak, fall apart, or burst open?
"well made" referring to quality of construction, I presume? Do we know anything about how well they filter engine oil?
If the criteria for good vs. bad is having "....no problems..." then I would have to say the Bosch filters are perfectly satisfactory, as I've used them many times with "no problems".
Beyond the general quality degradation we've seen over the decades we also face (and this brings me to my favorite rant) global manufacturing and distribution schemes which make it hard to tell what you're buying these days. Everything, seemingly, is label-engineered. For all I know the Bosch filter we get in the USA are different than the ones sold in Europe which are different than the ones sold in Australia.
Define 'problems'.
and
Which ones? And what's the definition of "really, really bad"?
"Bad", presumably, because the shorter length means less filtering capacity? if so, is the reduction so significant that the filter must be rated as "bad"?
Or, can we apply the "no problems reported" standard? For at least one of us, 'no problems' makes even the Fram OK....even though Fram is supposed to be one of the "bad" choices
And, what "bad" thing happens if you use them? Does the engine blow up or what?
Years ago...maybe back in the 80s.... Jaguar itself rationalized the long and short filters, and offered just the short version. So, should we then characterize the OEM filters as "bad" because they're shorter than they used to be?
(I might add that I've never heard a conclusive answer as to who makes the OEM Jag filters. Word on the streets is two or three suppliers have been used over the last 20 years or so. Presumably they're all good enough to satisfy Jaguar....but what do we really know about them?)
Indeed, and Bosch list several part numbers for Jags. It gets confusing. Some online sellers list the specs so an observant buyer can compare.
In some cases (perhaps Bosch? I dunno) filters are offered that don't even match original build configuration---the most obvious and common deception is filters without a check valve being sold for applications where a check valve is called for.
This is similar to another conversation about Stant offering several thermostats for a single application. All were decent quality...but only one was the actual *correct* thermostat.
But are they "bad"? Or "really, really bad" ? Or are they simply less-than-premium?
Without clarification of what is meant, or what standard is being applied, describing filters as "bad" or "really, really bad" isn't perhaps the wisest choice of words, either.
With regard to Bosch, I checked the application against the Bosch book so it's not really the fault of the seller. Bosch just decided in their quest to cover as many applications with as few numbers as possible to take a shortcut. If someone takes one shortcut, then one has to wonder what other shortcuts have been taken. It's a pride of ownership thing.
Now, since that first purchase, I have had the opportunity to heft the Bosch item in comparison to the Mann item for the same application. Much sturdier and weighty. Similar to some of the observartions about the Baldwin in the Ferrari application. Yes, after you mentioned them, I took off down the rathole
Now, one data point about the Bosch "shortcut" and being shorter ... in one application the Bosch had 87 square inches of filtering media ... the least of all of the filters in the group ... while the top end was in the range of 250 square inches. All in the same size canister. Lovely black and red paint job ... but if you knew about the 87 square inches would you select the filter in preference to equal priced alternatives.
Now, that is one application ... but if you get food poisoning at a restaurant ... is is necessary in the name of "science" that you return and sample every item on the menu? Certain members of JF would insist that you do so.
As for "less than premium", that's just a polite way of saying "total crap not worthy of consideration". But, since so many people are swayed by marketing, I left it at "less than premium".
Something to know about Mann filters ... the ML prefixed application numbers are not made in Europe but instead are part of an acqusition. They tend to be subject to the same "engineered to be cheap" methods used by the former market leading names ... like Fram.
These names engage in badge engineering with products bearing the same numbers being manufactured in market specific facilities and designs. The US market being a market enured to disposable everything happens to accept crap happily.
Others ... not so much. The story on Lacoste golf shirts is that no Asian tourist would ever dream of buying one for a souvenir because the US market shirts are made from inferior fabric. Market specific design rears its ugly head.
Once in a while, you can benefit from badge engineering on small volume items. For example, buy the right number in either Gates or Stant (same company), NAPA and inside the box will be a thermostat stamped WAXSTAT, the exact same thermostat sold at the dealer. They didn't make it, the volume is too small. Instead, they buy it stuff it into a branded box.
I got blamed because numb nuts picked the cheapest number of the several alternative without looking. Saved a whole $3 or so and then started ranting about how he was somehow entitled to some sort of unspecified redress for his self inflicted pain.
Not my probem if he won't do his own due diligence. And that is the real point ... actual independent, critical thought.
The way things are going, there will be no population explosion problem so long as Darwin's Law continues to hold. The problem is that governments are doing their best to repeal the law.
