Please help Timing issues after rebuild??
Old 06-01-2011, 01:20 PM
smitty5534's Avatar
Default Please help Timing issues after rebuild??
Ok guys I have a 98 XJ8 that a spun a rod bearing in we rebuilt the bottom in. Heres the problem im having:
THe heads are on the motor and with no cams bolted down on the heads the motor turns over no problem. When I bolt the cams down to the heads bring the flat sides up, put the locking tool on the cams and put the plug in the flywheel and put all the timing chains on and turn in over its turns for a mintue then a valve hits a piston and of course I stop.
My question is what am I doing wrong I followed the write up that everyone uses and its doesnt seem that compleX. I think Im doing something wrong in the vvt part. Is there a special way to put the vvt. I take the slack out of the chain like im suppose to and then use the tensioner to hold it on the oppsite side and still when I go to turn it over by hand it hits. Does anyone have any advice thanks in advance
Old 06-01-2011, 01:31 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
smitty:
I gotta ask- Do you have the correct cams in the correct heads? They are not the same, as I recall. Also, when you pull up the slack, you are pulling CCW on either exhaust cam, right?
Old 06-01-2011, 04:38 PM
smitty5534's Avatar
Yes Im sure the cams are right bc everything was neat and labeled. Yes the only way to pull up slack is to rotate the vvt ccw which I am doing. Im open to any other ideas as I am at a stand still unless someone smarter then me can help thanks in advance
Old 06-01-2011, 04:43 PM
smitty5534's Avatar
I read some theads about unwinding the vvt is there more to this timing job then just setting the flat sides of the cams and putting the plug in the crank sensor hole?
Old 06-01-2011, 07:31 PM
sparkenzap's Avatar
If you pull up the slack on the exhaust sprocket CCW, you have unwound the VVT unless it has some obstruction holding it advanced, which I have never heard reported.
I have never been there (yet) but does the flywheel only go on in one orientation?
Old 06-01-2011, 08:29 PM
jaginblack's Avatar
It sounds like you might not have the crank in the right position when the cams are locked. You are taking out the crank sensor and replacing it with the crank positioning tool and it is falling into place all the way?
Otherwise, I have to wonder if the cams are switched and I can't recall if they are factory marked bank A or B. Or a valve is sticking open and hitting when it should be closed
I don't believe you actually have VVT in a '98. It should be lock the crank, lock the flats, tension the chains, that should have things in sync.
Old 06-01-2011, 08:32 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
The VVT's alone are not capable of causing the problem you describe. They operate just fine within their range of movement. And I believe the early engines had VVT's but they were off/on not variable.
Sounds like the primary chains/intake cam may not be correctly timed to the crank.
Old 06-02-2011, 02:47 PM
popeye68's Avatar
Silly question maybe ...
But , did you turn the crank in the right (clockwise) direction ?
Old 06-03-2011, 12:06 AM
dsnyder586's Avatar
Is it possible that the flex plate with the special tool hole is not put on in the right position?
Old 06-03-2011, 05:05 AM
Sean B's Avatar
Received 1,339 Likes on 1,057 Posts
Camshaft Timing
Check that the crankshaft is positioned to 45º ATDC
with a JD 216 drive plate locking pin installed.
Using a JD 215 camshaft locking bar, check that
the camshafts are held with their flats up and
parallel with the top face of the cylinder head.
Check that the VVT units are fully retarded.
Tighten the ‘B’ bank primary chain by inserting 1
or 2 JD 218 timing chain tensioning wedges between
the ‘B’ bank primary chain tensioner and
the tensioner blade.
Fit the JD 217 timing chain tensioner tool to the
‘B’ bank exhaust sprocket and apply 10 – 15 Nm
(7 – 11 lb ft) counter clockwise torque to the
exhaust camshaft sprocket while torquing the
exhaust camshaft sprocket bolt to 110 – 130 Nm
(81 – 96 lb ft). Continue to hold the tension and
torque the intake camshaft sprocket bolt to
110 – 130 Nm (81 – 96 lb ft).
Repeat the procedure for the ‘A’ bank chains.
Remove the JD 216 locking pin from the drive
plate, the JD 215 camshaft locking bars and the
JD 218 timing chain tensioning wedges.
NOTES
JD 218 TIMING CHAIN TENSIONER WEDGE
T180/2.34
JD 217 TIMING CHAIN TENSIONER TOOL
T180/
Old 06-24-2011, 01:31 PM
ThePip99's Avatar
Default Question to Sean B...
I have a question about Sean B's response, and I am familiar with, and agree with all that you have said ... but as I read in the JTIS CD disk service manual, they have the same info and torque valuefor for torquing the bolt on the exhaust cam, but when it comes to the inlet cam, the factory JTIS CD says to first put 30 ft-lb (about 40 n-m) on the inlet cam / VVT bolt, and then to apply additional 90 degree "turn the bolt". I see that your info to torque both cams the same basic 90 ft-lb. Could you please comment on this. I know that torquing by "turn of the bolt" a prescribed number of degrees, is a well established industry practice to assure you actually get the right torque (and preload force), but I am not so sure that the CD has a misprint in there, ... they say 90 degrees more, but that grabs me as an awful lot. I've done engineering calculations (my profession), and knowing the pitch of th bolt (1.5 mm), and the free shank lenght availablt to stretch (about 0.7 inch), at 90 turn, the bolt would be horribly overstressed ( and potentially break). I could believe 9 degrees though, that would put it in th sam ballpark with 90 ft-lb. Anyway, I would like to ask you know of this, if you've heard that's it's a misprint, or whatever you think. I think you've got it right, but am trying to understand what Jaguar's intent was on this really key bolt to make sure pistons dont crunch valves, and really make sur I've got it right as I'm re-assembling my engine now after changing the tensioners on my 99 XK8. Thanks in advance for your time!
Old 06-24-2011, 02:06 PM
Sean B's Avatar
I quoted the JTIS process, so I can't really comment, but I doubt a miss print. I'd contact a Jag tech if this is causing you to stress.
ThePip99 (06-25-2011)
Isoruku
06-19-2020 12:54 PM
Rupesh
03-25-2016 03:33 PM
NTL1991
XJ40 ( XJ81 )
09-24-2015 09:09 PM
Dion Petty
08-30-2015 01:00 PM
TC Johnson
08-29-2015 08:55 PM
Quick Reply: Please help Timing issues after rebuild??
