Poorly Retracting Seatbelt RESOLVED
My 2001 XJ8 has a very slow and incomplete retracting seatbelt (the driver's belt).
I can understand the wear and tear on this belt mechanism. Still, I wonder if this is common? Has anyone been able to fix or adjust/tighten the mechanism so the belt will retract quicker and all the way?
I have seen on some forums about other Jag models that pumping the brake pedal somehow helps this problem. What is that about?
Follow up:
I finally got around to looking at the possible twisted belt situation. That is what it was! On both sides.
I have seen other cars get a twisted belt because there is too much room in the guides. But the guides on the Jag are way tight. It took a lot of working to twist them back right. Just barely enough room.
And for what it's worth, on the passenger side the belt was not only twisted in 2 places but was also bolted to the seat frame backwards!
There was NO way to get in there with the Torx on a 3/8 inch rachet - but I did not want to remove the seat.
I ended up using a pair of Vise Grips and then chanel locks and that worked fine.
JimC64 (12-28-2013)
Received 9,005 Likes
Follow up:
Thanks for coming back on this Robert and for all who replied too.
I'm addding RESOLVED to the thread title so that it may assist others.
