driver-side speaker reaplcement options?
Old 10-27-2011, 11:23 AM
vincent661983's Avatar
Default driver-side speaker reaplcement options?
I must be deaf , I just found that my 2000 XJR driver side speaker did not sound since long time ago.
I am measuring for OEM Alpine or any advise for a even better after market replacement?
I believed size is 6 1/4 inch if I was correct
Old 10-27-2011, 08:06 PM
Ipc838's Avatar
On my system, I replaced 2 stock units in the front doors. I have the standard Philips speakers, but yes its 6 3/4 I think... I wouldn't replace 1 speaker with an aftermarket one, but if you replace lock, stock, and barrel, you would probably do well with a newer Alpine setup. Bowers and Wilins sells some of their products at exorbidant rates I think, maybe they have something in your size. Funny thing with the standard system, the speaker grilles are $10 more than the speakers themselves.
Old 10-29-2011, 03:34 PM
Well, I stopped by the Auto Audio shop and the guy took a brief look and he that might be the issue of the amplifier or stereo/radio instead the the side speaker since both front and rear big speakers were out but smaller were fine.
In case of the amp issue, Can I replace it with an aftermarket one or jaguar restricts with any codes?
sadepol01
02-08-2022 10:13 PM
GGabriel
11-22-2018 03:53 AM
Presence
03-13-2016 02:21 PM
magmedia
10-08-2015 03:28 PM
Johncy2000
10-02-2015 01:05 AM
Quick Reply: driver-side speaker reaplcement options?
