Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ ( X308 ) XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X308 ) XJ8 / XJR 1997 - 2003
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Self closing sunroof
LinkBack Thread Tools Search this Thread
Old 03-30-2011, 12:50 PM
Default Self closing sunroof
I open my sunroof, in either the slide or tilt position, and it "automatically" closes itself after a matter of 10-30 seconds. I do not push the button to close it, I'm thinking it may be a sticky connection or loose wire in the switch. Any others have a similar experience and find a solution? Thanks, Roger
__________________
Roger
JagLoverX2,
'99 XJ8, BRG/Cashmere, 78k
Old 03-30-2011, 01:13 PM
Interesting. Sometimes when I close mine and it's "self-closing" (meaning the 1-touch operation), it stops a few inches short of being fully closed and begins reopening.
Also, mine doesn't seem to automatically open with one touch.
Maybe someone can shed some light on this for us.
SirJag
__________________
2001 VDP Undergoing an extreme (mechanical) makeover. When this beast is ready for her unveiling, I'm celebrating by smashing a bottle of champagne over the previous owner's head.
Old 03-30-2011, 01:16 PM
Does it look like the roof is fully opening? -- The roof will reverse if it thinks it is hitting something.
The tracks need occasional lubrication. Needs to be the correct grease and not too much.
Also, be especially careful that the roof has fully closed. For two reasons: (1) it will leak and (2) if the roof is not in the correct "closed" position when you try to open it to the vent position -- the plastic clips in the track can break.
Every sunroof in all my Jaguars have been a problem -- all have required some work. I never use the tilt feature -- the clips have broken is all three of my recent ones -- unbelievable pain to fix.
Old 03-30-2011, 01:44 PM
Yes, sunroof is fully open, it stays open for a few seconds, the closes, what is the correct lube? Can I use lithium grease? I have used this on sunroofs on other cars.
__________________
Roger
JagLoverX2,
Old 03-30-2011, 02:20 PM
Thats strange -- I wonder if it has limit switches and if they require adjustment?
I do not know what the proper grease is -- I use a tube of Mercedes sunroof grease - it's not very expensive. It does not look like a typical white or Lithium grease. Often many of the lithium greases are too thick for.
It is light like the stuff for a garage door opener. Lubriplate - sells a garage door product that is lighter than the more common white product.
You need to clean the track off as well - just be careful -- lots of plastic pieces.
Old 03-30-2011, 02:42 PM
burmaz's Avatar
Quote:
Maybe recalibrating the sunroof module will help? You can actually get the sunroof to fully retact instead of the usual 75% opening if you play around with it. I worry it will break something when it goes all the way back into the roof, as if it could break the track.
__________________
Jaguar Vanden Plas V8
Old 03-30-2011, 03:45 PM
I just gave it a look on my way to the bank -- the grease is almost clear -- looks like a thick Vasoline.
Same color as the Jaguar stuff.
Tags
190e, 98, automatically, close, closes, closing, jag, jaguar, jaguars, opens, reopening, sunroof, sunroofs, tilt, trunk, xj8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
