SRS/Air Bag warning light
I've looked all over here and not found any threads relating to the SRS/Air Bag warning light.
Has anybody had an issue with this light coming on?
Now that we are dealing with this much heat, I'm using my a/c continually (normally, I only use it during extreme temps) and since I started using it daily, the air bag/srs light has been on. It has never come on before, and I don't know that there is any relationship, but the two things happened the same day.
If there is no relationship between the two, does anybody have any idea why your airbag/srs warning light would come on?
Hi
Are you also having any other issues like horn or cruise controls radio controls on the steering wheel?
Here is a forum thread - Airbag light stays - clockspring issue?
https://www.jaguarforums.com/forum/x...kspring-66408/
Jim Lombardi
Jim Lombardi
Sorry Jim,
Somehow I never saw any response notice on this post. I have no clue how I never saw your question. My apologies for ignoring you.
No, there are no other issues with controls on the steering wheel. It is only the Airbag notification, and it still is lit.
I guess I could as Jag themselves.
In the meantime, I've had to replace the thermostat housing (what a fun job!) but instead of the plastic, I got a cast aluminum. Seems good. And now the water distribution tube at the upper radiator hose is coming apart at the end, making the hose slip off in high heat. Well, not off, but loose...so I have parts on order for that. I'd like to be driving it again here.
