Starter removal help
Old 11-15-2011, 07:33 PM
JagLoverX2's Avatar
Question Starter removal help
Hi, I need to replace the starter on my '99 XJ8. Saw the post elsewhere regarding starter removal, but I have two questions:
What is a "U.J"? (The upper bolt may be removed (after loosening) using a 3/8' square drive 13 mm socket, extensions and U.J as shown.)
Any advice on how to access upper starter bolt? Will the half moon wrench take care of that problem?
I really don't plan on removing the steering rack.
tia
Old 11-15-2011, 09:38 PM
Boomer from Boston's Avatar
I would guess that UJ = "Universal Joint" = swivel
but I could be wrong ....
Old 11-16-2011, 07:17 PM
jimlombardi's Avatar
Received 1,618 Likes on 874 Posts
Hi
The U.J. is the abbreviation for Univeral Joint tool (also know as a ratchet swivel flex universal joint extension).
This jpeg shows this tool attached to a rachet, the extension bars, the swivel, and the socket all assembled to give access the upper mounting bolt of the starter. Also a close-up of the swivel flex universal joint extension.
Here is information from the JTIS:
Remove the starter motor securing bolts.Remove the upper securing bolt. Preferably, use a short 13 mm spanner or a Snap On Half Moon spanner CMX1113 to initially loosen the bolt.
I think to 300 length is 300 mm or about 11 inches, and the 140 is 140 mm or about 5 1/2 inches.
Hope this helps
Jim Lombardi
TheBrightKnight (07-22-2012)
aholbro1
08-05-2021 05:02 AM
Shaggy9212
XJ40 ( XJ81 )
09-14-2015 08:08 PM
1964Daimler
09-09-2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
09-06-2015 10:54 AM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: Starter removal help
