Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ ( X308 ) XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X308 ) XJ8 / XJR 1997 - 2003
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
LinkBack Thread Tools Search this Thread
Old 10-20-2011, 10:12 PM
JaguarXJR02's Avatar
Default Supercharger problem?
Had my XJR in at a local European car specialty shop for fuel pumps. The mechanic directed my attention to an “interesting” noise the engine is making. The noise seems to only happen when the supercharger is changing its RPM.
I made a video of the situation; does anyone know if this is definitely a supercharger related issue?
Car is a 2002 XJR
68,000 miles
the noise is the "clanking" right at start up and at the beginning of the engine revs.
MVI 2011 - YouTube
__________________
2002 Jaguar XJR- 77,000 miles
"The car is the closest thing we will ever create to something that is alive" ~ Sir William Lyons
Old 10-20-2011, 10:19 PM
I would disconnect the SC and make sure it the source of the noise - they are normally robust
The Following User Says Thank You to yeldogt For This Useful Post:
JaguarXJR02 (10-21-2011)
Old 10-20-2011, 10:37 PM
plums's Avatar
"clanking"? as in a bicycle chain rubbing against a chain guard?
That would be cam tensioners/chain.
The supercharger does not change speed independently of the engine. So, it could be anything changing speed.
On the other hand, if it is at the supercharger drive snout, it is the supercharger drive. Rebuild kits are available.
The Following User Says Thank You to plums For This Useful Post:
Old 10-21-2011, 04:17 AM
Sean B's Avatar
Yep, drop the SC belt off to confirm - the engine will run without issues with the SC disconnected, if the noise isn't there, you can assume its the charger - your model year hopefully means your engine has metal tensioners, so we could rule out timing parts making the noise, possibly....
Is the noise more prevalent when it comes off revs? If so you'll need one of these fitting....it's the one thing that can cause this kind of noise. The coupler.
Eaton supercharger coupler M90 Thunderbird Etc New BIN | eBay
__________________
*2002 XJR 100'S' - Better than new.
(Imitation is the sincerest form of flattery)
*1964 E Type Roadster
*1962 E Type Coupe
*1966 MKII 3.4 m.o.d
The Following User Says Thank You to Sean B For This Useful Post:
Old 10-21-2011, 06:10 AM
Vector's Avatar
Untitled
Sean,
Where does that coupler install in the SC?
Vector
__________________
"I have come to understand that owning a Jag is like owning a horse. There's no joy in it unless you love taking care of it."
01 XJR, Anthracite Pearl Metallic/Ivory
Secondary Tensioners done.
RealGauge. Antenna switch installed. Trans fluid changed. Supercharger oil changed.
Red Calipers. Electric exhaust cut outs installed, WOW! Fender leapers changed to side markers.
Old 10-21-2011, 08:59 AM
Sean B's Avatar
Quote:
Originally Posted by Vector View Post
Sean,
Vector
On the front of the top rotor. If you have to ask, leave it to the experts.
__________________
*1962 E Type Coupe
Old 10-21-2011, 09:23 AM
motorcarman's Avatar
Photobucket
I use these type of couplers to repair the Eaton M112. The M90 uses the same coupler.
Eaton GM Ford OEM Supercharger Coupler NEW | eBay
bob gauff
__________________
Owning and repairing British and German cars since the early 70's
2001 XJ8 Mistral
1999 XJ8L Topaz
1985 XJ6 Belgian Import (Gray Market project car)
1985 XJ6 (Parts Car)
1983 XJ6 (Parts Car)
1992 Sovereign (sold)
2001 S-Type 4.0 (sold)
1997 XJ6L Black (sold)
1997 XJ6L White (sold)
1972 XJ6 (sold)
1966 'E'Type (first Jaguar) (sold)
The Following User Says Thank You to motorcarman For This Useful Post:
Old 10-21-2011, 10:22 AM
thank you for the replies
I removed the supercharger belt, fired it up and it didn't make the noise.
Looks like I'll be removing the supercharger and putting a new coupler in there or mailing my supercharger somewhere to let them do it.
__________________
Old 10-21-2011, 08:45 PM
Vector's Avatar
Untitled
I probably "can't afford it" either, LOL!
(If you have to ask.........)
Vector
__________________
Old 10-23-2011, 08:25 PM
this whole operation was a pain, but it's out. it's interesting how there are coolant lines into the throttle body and 3 coolant hoses under the supercharger, wiring clips everywhere, and many vacuum lines.
SC doesn't seem to be in too bad of shape
Supercharger problem?-sc1.jpg   Supercharger problem?-sc2.jpg   Supercharger problem?-sc3.jpg
__________________
Old 10-23-2011, 09:49 PM
Photobucket
Do yourself a favor and replace the coolant heater hoses in the engine 'valley' before reinstalling the intake system.
bob gauff
__________________
2001 XJ8 Mistral
1999 XJ8L Topaz
1972 XJ6 (sold)
Old 10-24-2011, 07:57 AM
Did you take any pictures of the hoses -- always wondered what it looked like under there!
Replacing the hoses sounds like a good idea .........
Old 10-24-2011, 02:11 PM
I'm not the OP but I got a ton of pics in this thread. The 1998 XJR 4.0 to 4.2 engine swap thread !!!:)
I can also post some more if you want to see anything in particular as I took a ton of pics and they are not all in the thread.
__________________
2002 911tt -Current DD and WW CF Mirrors, CF Ruf Spoiler, GT2 Bumper
1989- Ford Mustang GT 5.8-- far from stock
2005- Triumph Sprint St
2004- BMW r1200c Montauk
1970- Triumph GT6+
1998- Jaguar XJR 4.2 swapped
Old 10-24-2011, 09:44 PM
I think I will replace the hoses, I don't want to go through the supercharger removal process again.
And go with what adam 699 can give you, I won't be around the car again until thanksgiving sadly
__________________
Old 06-11-2012, 07:52 PM
Plums, where can I purchase a rebuild kit for a 2003 XJR Supercharger?
Old 06-11-2012, 10:00 PM
Go to UK Ebay and buy yourself IMO a 3lb stainless steel pulley and have PSE put it on for you and have them rebuild the SC.
Old 06-11-2012, 10:47 PM
Quote:
old thread, I had this all sorted out close to 6 months ago
Update on the XJR
__________________
Old 08-06-2012, 12:38 AM
Default Supercharger rattle
JagXJR02,
What was the final resolution to your supercharger noise? Did you have it rebuilt, and if so, did they find a definite problem? I now have the exact same noise as your original posted video on my 02 XKR.
Old 08-06-2012, 01:01 AM
Sorry, didn't catch the link to the new thread. Thanks for all the great info!
Old 08-07-2012, 10:58 PM
Quote:
no problem glad my issues can help others pin down their issues faster
__________________
Tags
1999, 2002, 42, belt, common, drive, eaton, jaguar, kit, problems, reubild, supercharged, supercharger, xj8, xjr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
