Vacuum routing help
Vacuum routing help
Hello everyone, happy 4th. I need some help. The previous owner of my 1998 xj8 left me a mess. They pulled out all the vacuum lines from the engine an i cannot locate the proper routing. I need to know starting at the vacuum reserve tanks(below air box) the way they go. they should continue to intake, fuel pressure regulator, throttle body and continue to valves(under drivers side cover, next to brake booster) I cannot determine how and where all of these spit (tee) off. Please can anyone take a look at theirs and detail this for me. Nothing is connected even to throttle body, not to mention if i push cruise switch it causes system to go into limp mode. Thanks agin for any help.
